07-02-2017 | #241 |
Re: TB removal and then some!!!
Preliminary test fit.....so far so good...
you can really notice the contrast in color between the plenum and cam covers, but that is for another time...
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member |
07-02-2017 | #242 |
I had my entire engine powder coated twenty years ago and it still looks good!
07-02-2017 | #243 | |
connectors connected, hoses attached, gaskets in place and some screws to hold all together until later... One thing I will have to do, which I should have done with the plenum off is to cut off the extensions near the coolant pipes, as I think my bleeder valves will be very close. Can always get the dremel out....
07-02-2017 | #244 |
If you are talking about coolant elbow attached to the plenum, you can grab it lightly with adjustable wrench and twist it back and forth until it pulls off. Hole can be plugged with metal press on cap. I think it was 3/8" cap. Check the hole diameter. May have been 1/4".
http://www.ebay.com/itm/ADD-ON-252-2...5TbmWH&vxp=mtr |
07-02-2017 | #245 | |
07-03-2017 | #246 |
07-03-2017 | #247 |
I tried removing one last night, did not want to cooperate.....may have to spray some WD40 to soak in. But that might not work because of the tight fit of these fittings. Have to wait and see how close the bleeders are when I put the coolant pipes back on. It just might make it, if it does I'll just leave them in place and cap them. I even thought about using double gaskets on the pipes to give me just that little bit of extra clearance.
07-03-2017 | #248 | |
07-03-2017 | #249 | |
Was ready to install the 12pt SS bolts to the plenum, but wanted to verify using washers with the bolts. That was confirmed, but need SS washers, I ordered no SS. So just ordered the washers I needed, so the install get delayed. On another note, the 10mm long socket works perfect with a long extension for in between the runners and all of them for that matter. Also a pencil magnet is a huge plus when installing or removing some of these bolts. Makes life easier.....lol wrong washers, but they look nice....lol checkout front bolt...and the 10mm socket and extension... pencil magnet for install & removal...a breeze...
07-03-2017 | #250 |
If the pencil magnet works on the SS bolts, maybe not SS?
"... ferritic stainless steels are generally magnetic while austenitic stainless steels usually are not. A ferritic stainless steel owes its magnetism to two factors: its high concentration of iron and its fundamental structure" Last edited by Mystic ZR-1; 07-03-2017 at 09:18 PM. |
Thread Tools | |
Display Modes | |
