06-11-2023 | #11 | |
Re: 90-95 Power steering pump solution
The one I ordered from volvette was reversed geared as for a Cadillac Northstar. I informed them of the problem and returned em for a refund. Did they correct them ? I have no idea. I would not want to relive the 4 installations it took me to determine the problem but the place I had the original rebuilt determined the components were reversed internally by design. Again for a Cadillac Northstar vs a LT5 ZR-1 Corvette. Bluntly it was a total PITA.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 06-11-2023 at 02:55 AM. |
06-13-2023 | #12 |
Hello all,
I just installed a modified aluminum ps pump that was modified by TurnOne in Saginaw, MI (989-759-4206). I talked with Mark and he was extremely helpful. The whole process was not a particularly easy job (5 hrs), but the TurnOne modified ps pump fit perfectly and, so far, is performing flawlessly. I'm very pleased after reading the ps posts here and being unable to find either a used or OEM replacement. Fair warning: it's releatively costly as it's a custom modification so it fits and works. |
06-19-2023 | #13 |
Information is saved in Post 5 - ZR1 Drive Train
Thanks Daryl STEERING 90-95 Power Steering Pumps Are ZR-1 Specific Power Steering Pump Repair Kit Replacing Power Steering Pump TIPS Make Your Own Power Steering Lines TIPS Sources of Fittings for Power Steering Lines TIPS Loose steering column TIPS Dimmer Switch TIPS Replacing tie rods Tie rod dust boots Rubber bushing kit Tilt Steering column wobbling Removing air bag TurnOne
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-19-2023 at 11:36 AM. |
06-21-2023 | #14 |
Thanks people!!!! Mechanice thinks it MAY just be the ps inlet hose which I just ordered and received from Corvette Central!! In the meantime just add fluid when needed
Thread Tools | |
Display Modes | |
