Old 08-04-2019   #11
Ccmano
Ccmano's Avatar
Default Re: Cooling Port for 1990 Lt5
As stated it was a press fit to begin with. I would use a sealant like clear RTV and put it back on.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 08-04-2019   #12
ZuggZR1
ZuggZR1's Avatar
excuse my newbieism i can get the rtv at autoparts store?
ZuggZR1 is offline   Reply With Quote
Old 08-04-2019   #13
ZuggZR1
ZuggZR1's Avatar
Which one is better:
1: https://shop.advanceautoparts.com/p/...hTerm=Permatex
2: https://shop.advanceautoparts.com/p/...hTerm=Permatex
I wann aget this fixed today if possible.
thanks again for all your help guys
Old 08-04-2019   #14
Ccmano
Ccmano's Avatar
Either will work, I would use the RTV.
H
Old 08-05-2019   #15
Originally Posted by TX '90 ZR1 View Post
I don't think Paul is recommending you JB Weld the fitting and use it. Think he is referring to blocking the coolant flow from the plenum with the plug (there are posts here on the forum detailing the procedure) and using the JB Weld to hold the fitting in place to give it a stock look.
Yes. You understood what I was trying to say.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 08-05-2019   #16
You won’t have to worry about any wise a$$ comments from this group,everybody gets along here and is more than glad to assist. As stated I’d bypass the TB and just plug the elbow back in and run some dummy hoses to the elbow to make it look like it’s stock,more or less. As far as trying to get it to stay in and use it for the intended purpose I’d think once it comes out there’s nothing that can be done to keep it in place,once it’s compromised,pulled out it’s done. If the plenum is powder coated maybe it was removed during the process.
Old 08-08-2019   #17
ZuggZR1
ZuggZR1's Avatar
Ended up using JB weld and placed back in after sanding the connector and cleaning up. let it cure 24 hours. Will test tonite when I jack up right side of car and add remaining coolant
Old 08-08-2020   #18
ram_g
Zugg, did this fix hold? Or did you need to do something else to permanently solve the problem?
Also, when the fitting came out, were you driving and was there an immediate sign of a problem such that you pulled over and stopped?
I will shortly start a new thread but I have a similar (not identical) issue.
ram_g is offline   Reply With Quote
Old 08-08-2020   #19
Corvette95
Corvette95's Avatar
Holley make a direct replacement, I have it on mine. You tap the port and screw in the exact press in fitting with the same upward twist...direct fit. It is one of these...sorry can't remember which. 782205ERL Earl's Vapor Guard? Hose End
782252ERL Earl's Vapor Guard? Hose End
782256ERL Earl's Vapor Guard? Hose End
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 08-08-2020   #20
ZuggZR1
ZuggZR1's Avatar
JB weld held and yes it happened while driving the Engine started to over heat
George Zugg
1990 DRM 500 ZR1
build#952
