07-14-2017 | #11 |
Re: Antenna Mast and Grommet
GM Part#10067979
07-14-2017 | #12 |
07-14-2017 | #13 |
07-14-2017 | #14 |
I know they were tough to find a couple of years ago when I needed one. I imagine that they're about nonexistent now. The good news is I bought two. I used one and sent my other one to a forum member so he could get them made. I'll have to send him a message and see if he's still interested. If not maybe he can send it to Jerry. Hopefully we can get them remade one way or another.
1990 ZR1 #2574 Medium Quasar Blue Metallic 1 of 19 |
07-14-2017 | #15 |
If the motor is running that tells me the mast is broken and the thing needs to come apart. One person can install the mast with the antenna housing in the car but it's a bit tricky. And also,nobody mentioned that there is a nut at the top of the housing that needs to come off in order to get the new mast in the housing and this nut takes a special socket to get it off,it usually comes with a new mast. Also,an antenna from a 93-96 will work in an earlier car but the wiring needs to be switched around. Early has external relay later has internal relay.
07-15-2017 | #16 |
One on eBay
http://m.ebay.com/itm/302376943367?_mwBanner=1
07-15-2017 | #17 |
Mike,
If you can wait until I get my '91 off the lift we can easily pull the assembly from you '90 and put it on the bench to diagnose.. Steve Sent from my QTAIR7 using ZR-1 Net Registry mobile app |
07-15-2017 | #18 |
07-17-2017 | #19 | |
1990 ZR1 Red/Black #2469 1990 ZR1 Black/Black #843 1993 ZR1 Ruby 40th Anniversary #112 |
07-17-2017 | #20 |
Thread Tools | |
Display Modes | |
