View Poll Results: What are the best plenum gaskets?
OEM 2 8.00%
Jerry's Gasket 1/32'' 5 20.00%
Jerry's Gasket 3/64'' 15 60.00%
Jerry's Gasket "early color" (gold) 3 12.00%
Voters: 25. You may not vote on this poll
Old 01-28-2016   #11
Jagdpanzer
Jagdpanzer's Avatar
Default Re: What are the best plenum gaskets?
Jerry's 3/64" gaskets has my vote
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Jagdpanzer is online now   Reply With Quote
Old 01-29-2016   #12
secondchance
Jerry's 3/64". I use Gaskacinch to glue the gasket to the plenum and use X-acto knife to port match before bolting it to the IH.
Old 02-01-2016   #13
fletchusmc
I voted Jerry's 3/64. Ordered them Saturday morning, got them today (Monday). Feels like a weak coil or a coil is going bad so will be pulling the plenum. From reading the recommendations I went with these.
fletchusmc is offline   Reply With Quote
Old 02-12-2016   #14
Johnny5
Thicker, you can get coolant leaks from thinner ones. At least i did
Johnny5 is offline   Reply With Quote
Old 02-13-2016   #15
Hmmmm..... In 7 years of maintenance and porting, etc., I have never had a leak w/ prolly half dozen of Jerry's gaskets. And, as a rule, I re-use them at least once, if not twice. However, I DO use Permatex around the coolant port for added insurance. My porting makes the web between the intake runner and the coolant jacket rather thin. But, as I said: No problems!! Just sayin....
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 11-24-2018   #16
jss06c6
I'm on my third set from Jerry. I replace with each plenum pull. 3/64" each time. I used a brand new set to scribe my plenum, injector housings and a set of IH gaskets for my primary intake runners on my heads on my '91 when I ported them. So, my engine is matched to Jerry's gaskets! Perfect results.. high quality product. I'm installing them on a customer's 29,000 mile 1990 right now..
Old 11-25-2018   #17
Yep. Permatex #2. And now I will be doing same to the crankcase vents.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
