11-27-2014 | #11 |
Re: Brighter Aftermarket Headlamps
GE Lighting sent me a set of its Nighthawk LED 5x7 rectangular headlights to test as part of the product review work I do for the Corvette Action Center.
I've run them for about a month in testing using both urban and suburban freeways and rural highways. The testing has been both at legal speeds and, uh...illegal speeds. So far, I'm impressed with their performance. The only downside I see is the price. They are pretty costly considering you can get Hella E-Code lights for 120 a set from some vendors. On the other side of the coin, if you compare Nighthawk LEDs to one of the few HID conversions which actually work well, they are less expensive. My Nighthawk LED testing is not done yet and, at the CAC, we also haven't finished necessary image work for the review. There seems to be some interest, so when the review is done, I'll post the URL here. Since this was originally an FS thread but is not more of a tech thread about lights, maybe one of the administrators should move this thread to a more appropriate forum?
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 11-27-2014 at 01:44 PM. Reason: changed working. |
11-27-2014 | #12 |
I went with the JW Speaker 8900 LED's, they are AWESOME. My Night Vision sucks anymore & I decided I needed these before driving to BG 2014. On the way back I got stuck driving way too late because of shortage of rooms. At about 3 AM, I seen 3 deer covering the entire road & pulled it down....with the stock lights, I would have plowed into one of them anyway. I paid $830 for the lights & saved a $1500 deductable, sounds like I made out.
11-29-2014 | #13 |
$830?!
Ouch! I'm not going to complain any more. The Nighthawk LEDs cost 2/3rds of that and, until now, I thought they were a little pricey.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 11-30-2014 at 06:41 PM. Reason: math |
11-29-2014 | #14 | |
Look forward to your review. |
11-30-2014 | #15 |
I'll put a link here when it posts on the CAC but...my review is not a comparison test between the three you mention above. It only covers Nighthawk.
11-30-2014 | #16 |
there is talk of these on CF..
I am thinking these will cause the C4 headlight/fog light wiring to be redone.. I know I want to do that as I am having some headlight issues with the fog lights and headlights
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
12-01-2014 | #17 |
Im still happy with my HIDs. I went this route after the silverstars and the H4 Hellas did not provide the light I needed. I have never looked back since. I did not go with the $99.00 crap specials on EBAY. I did it right with a kit made for our car using Euro projector housings with the cutout for the highs and the lowbeams. Also they offer a relensing service if the glass housing becomes damaged. WWW.Corvettehid.com Thats something im sure the LED folks do not provide.
Eventually im sure the LEDs will come down in price.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 12-01-2014 at 08:17 AM. |
12-01-2014 | #18 | |
LED headlights are the "wave" of the future I think. All the OEs are getting away from incandescent or HIDs and going with LEDs because they use so little current. Less current means they can make lighter wiring harnesses. Also, LEDs don't produce heat and the color temperature is closer to daylight. But then, again, there is the cost factor. Old skool, high wattage quartz-halogen bulbs in Hella or Cibie reflectors are less expensive than LEDs and less than the HID conversions which actually work well.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 12-01-2014 at 03:02 PM. Reason: added content. |
12-01-2014 | #19 | |
the fog lights are grounded through the High beams (90-older) so there would need to be improvements to that circuit. it was improved on the 91-later cars with a relay
12-01-2014 | #20 | |
Outwardly, the GE Nighthawks, the Phillips and the Truck-lite all look similar and the Phillips and the Truck-lite look identical. The lens on the current Nighthawk (which, internally, GE calls "Gen 2) is different. That said, it's possible there is only one manufacturer and which is private labeling all three brands. I'm going to try and confirm that but, sometimes, these companies will not give out that much information. All three brands use dual array designs. I have specifications for the Nighthawks and they are virtually the same as the Truck-lites. The only number which is different is the low limit of their voltage ranges. GE says 11-33v. Truck-lite says 9-33v. Otherwise, published specs are the same. Unfortunately, Phillips does not have in-depth tech. specs. available. My gut feeling is that since they all meet the same FVMSS and have almost the same tech. specs., that performance wise, there will not be any significant differences in performance. I've, also, researched CorvetteHID.com's product to the limit that its web site allows and I agree that a "relensing" service is an attractive feature, especially, if you drive in places were vehicles ahead kick-up little rocks and stones or you drive where your front end gets sandblasted at night. However, the fact remains, while at one time, HIDs were a good alternative to high wattage quartz-halogen bulbs in glass reflectors (if you could afford the over $1000 bucks the conversion costs)–HIDs, at this point in time, are becoming obsolete as LED technology advances. At current street prices, you can buy two complete sets of Nighthawks for what CorvetteHID charges for its conversion which fits C4s with functioning hidden lights. If you're ok with permanently exposed lamps, the CorvetteHID.com conversion is only $750. Finally, the nice thing about LEDs is you'd don't have to modify anything. You just open the lights manually, remove the bezel and retaining ring then unplug the stock stuff and replace it with the LEDs. Put the retainer and bezel back in place and you're done.
Thread Tools | |
Display Modes | |
