Old 06-17-2013   #11
RHanselman
RHanselman's Avatar
Default Re: Wtb Dewitt's radiator and spal fans
Just wondering, how are your oil temps?
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 06-17-2013   #12
Never beyond mid point. Temps really climb with Ac on. Bought new 2 row with spal fans.
Old 06-17-2013   #13
PhillipsLT5
PhillipsLT5's Avatar
http://www.summitracing.com/search/b...ew=ProductName
http://www.summitracing.com/search/b...s?autoview=SKU
Old 06-17-2013   #14
RHanselman
RHanselman's Avatar
I have the same problem with my Turbo LT1 car. The A/C drives the temps up pretty darn good when I was in Vegas... I'm going to pull and inspect the Rad and was thinking of upgrading the fans. Where did you source the Spal Fans?
Ron Hanselman
Founding Member #80
Old 06-17-2013   #15
RHanselman
RHanselman's Avatar
You're quicker than I was...
Ron Hanselman
Founding Member #80
Old 06-18-2013   #16
tf95ZR1
tf95ZR1's Avatar
My OEM radiator plastic tank separated from the core, so I used that as an excuse to get a Ron Davis radiator.
(I consider the RD rad in the same category as a DeWitt's.) To cool better, it is thicker than stock so I had to trim
the fan shroud. BFD. Car runs cooler in general.
Assuming the basics: radiator is clean and not blocked, coolant is correct (water wetter?), thermostat works, etc.
there are some other options to run cooler:
-Have you tried cooler spark plugs? Consider them your summer plugs.
-A high rise hood. Not only more room for air flow, but more air can suck in from in front of the windshield.
Not to mention how COOL it looks!
-Down shift. Counter intuitive, but it works. You can thank the Z's cooling system design.
Obviously in stop and go traffic this is useless.
-manual fan switches
I've never understood how a 160deg thermostat will make the system run cooler than a 180deg stat.
Yes, it will open sooner, but eventually the system temperature will rise to it's open thermostat "equilibrium" temperature
(greater than 160) regardless, right?
Old 06-18-2013   #17
Dewitts sells then as well as a direct fit... Im $900 lighter although
http://www.dewitts.com/collections/c...minum-radiator
Old 06-18-2013   #18
I agree
-Down shift. Counter intuitive, but it works. You can thank the Z's cooling system design. Obviously in stop and go traffic this is useless. -manual fan switches
Actually I got relief when I up shifted esp to 6th gear at freeway speeds in 5th the temp would slowly climb
I've never understood how a 160deg thermostat will make the system run cooler than a 180deg stat. Yes, it will open sooner, but eventually the system temperature will rise to it's open thermostat "equilibrium" temperature (greater than 160) regardless, right?
Your right as I understand it a specific temp of a thermostat allows the passage of rad water beyond a specific heat range. Its actually better to keep the water in the radiator as long as possible as thats air cooled before letting it go into the rest of the motor. So a 160 allows the water to start flowing sooner however all the cooling occurs in the radiator. Hopefully the increase in capacity and bigger fans will resolve my issue. D
Old 06-24-2013   #19
Holly Crap Dewitt's finally shipped the radiator a week after I ordered wow. Very slow IMHO.
Old 06-24-2013   #20
tf95ZR1
tf95ZR1's Avatar
Hey be careful, GC.
Aren't they a supporting vendor here?
Don't want to be banned.....
Oh wait, you're a mod!
