Old 12-09-2012   #11
Blue Flame Restorations
Default Re: Engine Dyno info from Mercruiser
This is about as close as anyone will ever get to seeing actual Dyno numbers during the "development" of the LT5. This data is from Jan 88. This booklet was prepared for all meeting attendees for the "go ahead" to produce the production model of the LT5. This meeting was held at Lotus, in the UK, between GM and Lotus engineers.
This is the Holy Grail for us.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 12-09-2012   #12
This is an actual LT5 Engine Build Booklet. This documents the entire build of the engine and is all hand written by the assembly technician. LT5 Engine 046. Look at the engine closely. There are several characteristics that differ from typical production LT5 motors.
Old 12-09-2012   #13
Brett is this the stuff I scanned or more?
Old 12-09-2012   #14
The Engine Build Booklet was not scanned.
Old 12-09-2012   #15
Kevin
Kevin's Avatar
Old 12-09-2012   #16
Originally Posted by Kevin View Post
Neat piece, Kevin. Do you have a full page pic you can post?
Old 12-09-2012   #17
Brett,
Yeah quite a few details that are different from production motor.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 12-09-2012   #18
Fully Vetted
Fully Vetted's Avatar
I think we should collectively make another push. Especially considering that the old GM no longer even exists.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 12-09-2012   #19
Mystic ZR-1
Mystic ZR-1's Avatar
Attached is what's in the NCRS archives for LT5 dyno sheets (also LT1). Many thanks to Bill Sangrey, the NCRS Archives Manager! OBTW, earlier this year Bill spoke with the NCM big wigs @ the NCRS Winter Regional in Florida and tried to "spring" the dyno sheets from the vaults of the NCM Library for us, unfortunately he wasn't successful If they won't give them to NCRS, they ain't giving them to anyone... It's easier to get "secrets" out of the Vatican...
The attached "Interim Test Report" from GM Powertrain, done @ Lotus in Hethul England is the results of the dyno runs they apparently used when determining the advertised horsepower for the 1993 LT5. The LT5 stuff is several pages into the attachment after the LT1 stuff.
Note: the LT5 put out 445.3 hp @ 6600 rpm!!! (pretty stout!!! I'm sure this is "at the crank" horsepower and who knows if any or all accesorries were installed?)
My computer skills could use some work so I hope the attachments "work". I've never tried to attach a pdf file to a Forum post. If I screwed it up, I'm open to suggestions.
Doug
aka: Mystic ZR-1
File Type: pdf LT 5 dyno sheet 07-NCRS 0277A - J - 1993.pdf (263.8 KB, 97 views)
Old 12-09-2012   #20
Cool stuff!!!
