#11 |
![]() ![]() Join Date: Feb 2007
Thanks Scott. I hadn't seen the latter part of your quote in my previous searches on the Registry.
I understand this is not a problem in the 93-95 model years. If that is true, does anyone have a schematic of the GM-updated start-up circuit? |
#12 | |
![]() ![]() Join Date: Nov 2007
Dom, when you say "starter rebuild", you refer to the armature (w/ new ring) and posts exclusively, or more than that?? P.
#13 | |
This solution resonates with me. I neglected to mention in my initial post that when my engine would not crank, I could hear my mod relay kicking in when I had the clutch depressed and the key on; so, the starter circuitry was working and the relay was delivering 12V (or something very close) directly to the starter. It seems to me that the starter was so heat soaked that with its current design, even a "normal voltage" is not enough to crank it once it wears a little. |
#14 |
![]() Join Date: Dec 2004
Is this what you're remembering Scott?
http://zr1netregistry.com/ZR1_troubleshooting.htm#Start It's from our mothership's Maintenance section, "Troubleshooting" tab. ZR1North, I just threw the ignition key switch issue out as another possible candidate for the "usual suspect" list because we as a group don't have it listed in our archives as one of the suspects. I'm sorry if I came across as that was the cause. My apologies. ![]() Tom
#15 |
Just replace the starter. They are only about $120 from an auto parts store. You get a new or rebuilt starter with a new or rebuilt solenoid. When it happens only when your engine is hot then its not intermittent. If it happens when it's cold then it's most likely a clutch switch or something else. Mine had no start only when it was hot and I replaced the starter and have never had a problem since. That was three years ago.
#16 |
![]() Join Date: Nov 2011
I had the same problem last year. It would not stat if the engine was warm at all. Ii bypassed the clutch safety switch, still no start. Installed the new relay, still no start. Ended up replacing the starter and installing additional ground strap from starter to batterie. I have not had a starting problem since. Just my .02
Chris
91 ZR-1 Red on Red #922 |
#17 | |
![]() Join Date: Jan 2009
When we first read about someone's problem with the car we pretty much all pull up what we had as a solution. A normal response. Sometimes we can save an OP time because what we had as a solution is the most common fault. However, if its not the most common resolution it can lead the OP down a path. On this particular issue someone way before me put together a real good 4 step efficient traversal. I'm not even sure who did it anymore. I keep it fresh in my head. Ya never know when "no start" will happen next.
Scott ![]() Vett owner since 1979._It's about the car and the people Last edited by scottfab; 08-13-2012 at 10:25 AM. |
#18 | |
I think one of the best points coming out of this latest discussion is that there are multiple causes for the no-start. The starter seems to be the likely cause when it won't crank when hot only. However, the other clutch switch, starter relay and ingnition switch are all issues as well. We might be wise to retain a rigrous maintenance regime on all those parts. Add to those VATS maintenance or override and we likely have it covered. Great discussion as always. Bob |
#19 |
Thanks Bob for not thinking I was trying to be a wise guy!
![]() ![]() Tom
Thread Tools | |
Display Modes | |
