11-25-2009 | #11 | |
Re: Group Buy on AC Compressor R12 OEM Denso 471-0336 with Clutch??
[quote=xlr8nflorida;75454]
The 90-91 are the same compressors, BUT not the same clutches, the 91-95 uses clutch part # 10243785, also, the 91-96 LT1 - LT4 cars clutch isn't the same as the LT5, they use part # 10243784 The only differences with the 90-95 clutch assemblies are the wire connectors, the 90 is unique, the 91-95 are the same for all years. Gets confusing i know, but you should try and inventory this ****. |
04-18-2010 | #12 |
Bump for an old thread -- AM I understanding correctly, that a 1990 compressor can be used in a 1991, if the wiring harness connector is changed? Or is there some other difference that makes this impossible?
Thread Tools | |
Display Modes | |
