#11 |
Tom, Secure the bottom first, if you try to mount the bottom last it can be tricky, it will sometimes be an awkward angle.
Then after the bottom has the nut started, you can then jack up the spindle and tighten the top bolts. Then go back to the lower and torque the large bolt. The upper bolts just won't take the strain of sucking up the suspension. |
#12 |
![]() Join Date: Dec 2004
Thanks Jeff! That is what I thought. I just was scared by the "!" in the FSM about the "suspension proper trim height" .....over thinking on my part again
![]() ![]() Now I can finish what I started last saturday! ![]() ![]() Tom
#13 |
Updated images
#14 |
I have these codes for my ride control:
Code 13 = Left rear time out Code 14 = Right Front time out What does "time out" mean in this case...what is the problem/solution for this? Thanks, Jarvis |
#15 | |
![]() http://captainzcnc.com/ is a great site for the troubleshooting process.
#16 |
Anyone have a way to thwart the light? I've pulled the shocks and actuators and they're not going back anytime soon.
Of course, I haven't yet looked to see if it gets its' own fuse. What happens if I pull the controller? Thanks, - Jeff |
#17 | |
1. Put the system back in 2. Put a small piece of electrical tape over the light 3. Remove the DIC and pull the bulb 4. Ignore it
#18 |
I'll investigate....thanks for the help!
#19 |
No problem, glad to help. GC
