Old 06-01-2010   #11
Ccmano
Default Re: ABS ASR Lights coming on
dunno.. quick trip so I don't know how much time I will have
Call me if you have time when your out here.... my cell hasn't changed. If I'm not employed or on an interview, let's do lunch.
H
Old 06-01-2010   #12
Hans, I will try.. Like I said, not sure how much free time I will have
Old 06-01-2010   #13
could be.. I assume it never self-tests?
also take the Tech 1 out of the loop and do the paper clip trick on the CCM, that might work to show the ABS codes
Old 06-01-2010   #14
I will check the brake fluid when I get it out again, I would be surprised if the ABS is dead with 22K miles, but anything is possible. I thought the same thing about the module. I have the $20 plug in tester with the ABS option and I get nothing
Lee
Old 06-18-2010   #15
Well, no brake fliud problem.......Next?
Old 06-18-2010   #16
See post #10 Lee
GOLDCYLON is online now   Reply With Quote
Old 06-25-2010   #17
ASR/ABS lights are off......I had an on again off again issue with the E brake light staying on.....that stopped.....so did the ASR/ABS.
Not sure if they are tied together.
Old 07-21-2010   #18
Confirmed there is a relationship between the E-brake light and the ASR/ABS light. E-brake light stayed on and ASR/ABS lights came on shortly after, had not had this for weeks.
