For the 402 LT5 stroker project I will be ditching the secondaries.
Turned out these aluminum pieces on the lathe to plug the shaft bores remaining in the cylinder heads. The plugs are slightly oversized, sealed with a dab of Loctite 462 and driven in with a hammer. Protruding part will be taken care of during porting. For the upper blind hole I drilled a small hole through the plug in order to vent the air trapped behind it as it was driven in. ![]() ![]() ![]() |
![]() Join Date: Dec 2003
Are you an engineer/machinist or sumpthin?
Very nice Phil.
Thanks Jerry, I'm an engineer and picked up running machine tools while in the navy.
I now work for MAN Diesel & Turbo. http://www.mandieselturbo.com/0000002/Home.html |
I knew you were an engineer Phil, from our conversation in Alexandria last year. I was just funnin' with you.
![]() Join Date: May 2008
Nice work Phil, looks like the beginning of a quality project!
Joe Thomas Corvette Club of Michigan NCRS-Michigan Chapter Member NCM Master Ambassador NCM Lifetime Member Former NCM Board Member 1991 ZR-1 Melon Copper Metallic/Black 1992 ZR-1 Bright Red/Black (Sold) 1995 ZR-1 Bright Aqua/Gray (Sold) 2012 ZR1 Super Sonic Blue / Dark Titanium |
![]() Join Date: Feb 2009
Phil, you are a true craftsman!!! Wish I could do that stuff with metal.
Rich
