Old 06-08-2010   #1
Ccmano
Ccmano's Avatar
Default Powder Coating the Throttle body?
I'm helping a friend with a top end refresh and we're doing powder-coat. Question is, does the throttle body need to be disassembled for powder coating or will the springs and plastic pieces tolerate the curing oven?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 06-09-2010   #2
rhipsher
rhipsher's Avatar
Default Re: Powder Coating the Throttle body?
I completely dissesembled mine. To me if your going to do it you might as well do it right. You will be glad you did. It will look spectacular at any angle and in any light.
Old 06-09-2010   #3
Ccmano
Ccmano's Avatar
How did you deal with the throttle plate screws and adjusting the plate positioning.
H
Old 06-09-2010   #4
Suggest calling Jeffvette, He maybe able to answer those questions for you and can be found a PNZR-1 http://www.pnwzr1.com/
Old 06-09-2010   #5
phrogs
phrogs's Avatar
I take mine apart as well, I took a sanding disk that I have that fits inside the back of the throttle plates and sand down the back of the screws so they will come out, when reinstalling the screws I use lock-tite.
JOHNNY P
Currently own
Old 06-09-2010   #6
rhipsher
rhipsher's Avatar
Mine were swaged down inside the holes so that wasn't an option for me. It will mess the threads up so I just drilled and taped it to the next size up.
I just ground them to the right length.
Old 06-09-2010   #7
Ccmano
Ccmano's Avatar
Can the primary stay in place? The temperature does not affect the spring?
H
Old 06-10-2010   #8
Ccmano
Ccmano's Avatar
Do you have one small enough to get in there and do the primary throttle plate or do you leave that in place?
H
Old 06-10-2010   #9
rhipsher
rhipsher's Avatar
I left the primary in place. you have to take the secondary plates out because there are thin plastic spacers behind the throttle cable springs and will melt when they bake it at 600 degrees for 6 hours 2 burn off any contaminants.
