![]() Join Date: Feb 2006
Something I have been dealing with but just forget to ask.
when I chk the oil and install the dipstick all the way it engages fine at the handle and end of the tube like any other dipstick does. but...... when i go to check the oil few days later its allways sticking out about a half inch or so, like I didnt engage it all the way. so i've pushed it back in took for a granny few mile drive and ck it and its fine. but when i go terrorize the neigborhood and chk it it is out... I dont know if I need another stick or tube or what. any ideas what causes that? and any ideas on the fix? ![]() Luis |
Crankcase pressure may be building up pushing the dipstick out.
Time to give the PCV system a good look over. |
![]() Join Date: May 2008
Agreed, something is not right. Check PCV out sooner then later
![]() I wouldn't be wailing on it until you get it figured out. Too much crankcase pressure is not good. Last edited by xlr8nflorida; 06-06-2010 at 10:15 AM. |
a month ago or so, i just replaced them, maybe 300 miles on them.
but will check again too make sure. |
#5 | |
ok chk'd the pcv's they are fine.. messed with the dipstick and it really doesnt seem to be enaging, like a snap fit or tight at all. I barely pulled on it and it moved out. |
![]() Join Date: Mar 2010
I have one that the t handle is broke off, but seals great it you want to give it a try
#7 | |
![]() http://jerrysgaskets.com/store2/root...products_id=40 |
yea !!! maybe so, where it says " at the bottom of the tube " forgive my ignorance
but does that mean i have to completely remove the whole tube from the side of the motor? thanks Luis |
#10 | |
![]() ![]() Last edited by Dynomite; 06-08-2010 at 12:07 AM. |
