Old 04-28-2010   #1
Default When is a clutch slave cylinder not a clutch slave cylinder?
I have the car up on jackstands getting ready for trip to BG in a few weeks. Changed trans fluid, changed spark plugs, looking at exhaust(see thread), and I thought I would pull clutch slave cylinder to do a look see on the plunger sealing. When I went to drain clutch fluid by opening bleeder valve, the barrel of the cylinder rotated. I was pretty sure that meant new slave cylinder. Ordered a DOM replacement from Advance Auto for $74 plus shipping. Hoping it gets here by Friday. In the meantime, =Jeff= took mine apart and although the plunger seal was on correctly, it was pretty loose in the housing and the ridges of the seal were non-existent. I may have found why my clutch engages near the bottom of the pedal stroke. Stay tuned.
Old 04-28-2010   #2
PhillipsLT5
PhillipsLT5's Avatar
Default Re: When is a clutch slave cylinder not a clutch slave cylinder?
Napa may have in stock, Bill B is the expert on slave
Old 04-29-2010   #3
Bought my last one on Ebay. Very happy made in the UK.
Old 04-29-2010   #4
Scrrem
Scrrem's Avatar
I was wondering about those. The housing looked like is was cast not stamped, maybe is was just the picture.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 04-29-2010   #5
Mine I believe was cast. I posted a link in an earlier post with the vendor who was selling the UK version
Old 05-01-2010   #6
Sgreg
Sgreg's Avatar
When is a clutch slave cylinder not a clutch slave cylinder ? When it's a knock off and cast material.
Sgreg is offline   Reply With Quote
Old 05-01-2010   #7
I dunno, my cast slave cylinder works fine..
Old 05-01-2010   #8
Sgreg
Sgreg's Avatar
And it may continue to and it may not. My GM/ACD slave is 18 years old and still works fine. Let me know 18 years from now !!!! I know I hate laying on my back at my age. If I replace mine, I want to do it once.
Old 05-01-2010   #9
I went through 3 slaves on my 89.. all were AC Delco..
2 leaked from areas other then the seal
I am pretty sure my Cast one was made in Mexico too, just like the DOM ones
Old 05-02-2010   #10
The Advance Auto slave turned out to be a cast piece altho the website illustration showed what appeared to be a DOM version. I had removed the hydraulic hose from the master in order to allow slave cylinder to drop further so I could undo hose at slave. Unfortunately, I ended up stripping threads inside master when I tried reattaching hose. Word to the wise, aligning the fitting with the female outlet of the master cylinder is a bitch without undoing hose clip on firewall and loosening master cylinder attaching bolts. I think there was an issue with the master to begin with. Al at Brakes Plus to the rescue. He had a DOM master sitting around and so we swapped the guts of his old one with mine.
Internals looked pretty good. This time I attached hose at master before bolting master to firewall. Luckily, the threads on the hydraulic hose were not damaged. Al had given me a spare fitting and double flare tool set if I needed to replace male fitting. Now I'm ready to attach rod to clutch pedal and start buttoning things up followed by bleeding system. Should be on the road later today. We'll see if that addresses the low pedal engagement issue I was having. I hope to "fix" my exhaust constriction next and then should be ready for trip to BG. Thanks Al and =Jeff=.
