Old 04-26-2010   #1
todesengel
Default Re: Constricted Header Collector?
I would also like to add that I do not buy magnaflows response to a restriction towards the tail end of the exhaust. It just seems contrary to theory.
First ask yourself what happens when exhaust gases cool, they expand. With expansion of gases it slows and requires more area to evacuate. For this reason you see a lot of people run 2.25"-2.50" headers which dump into a larger system down the line and/or a exhaust system that "megaphones" towards the tail end to compensate for the expansion of these gases as they cool. For this reason, imho, it would seem "better" to have a restriction on the front end, where the gases are still hot, than the back end. The "better" solution, again imho, is to have a consistent system OR one that expands to take into account the expansion of gases, OR the best solution which would be a system that is coated, or wrapped, to limit gas expansion AND enlarges towards the discharge.
todesengel is offline   Reply With Quote
Old 04-27-2010   #2
flyin ryan
flyin ryan's Avatar
I find all this talk rather interesting. On my Stingray, I have SPD build a choke into my collectors on purpose. This one is identical, Divergent & Convergent angles, to the ones on my Stingray, I just have an extra set for dynoing only as the ones on my Stingray are welded to the exhaust.
Old 04-27-2010   #3
Well...Gasses do NOT expand as they cool; just the opposite (or a lot of thermal dynamics texts books got it all wrong!). Put the cap (seal) on an empty plastic milk jug at room temp and put it in the fridge, if ya wanna see for yourself.
But, I agree, from a fluid dynamics perspective, that a consistent size (i.e.) uniform throughout is important - as opposed to varying diameters abruptly (especially abruptly!) along the way. Otherwise, there are acoustical energy consequences (turbulance being one byproduct); hence the funnel designs you see on some intake porting jobs, AND, (to your point) the same is true on some exhausts, tho not so much on anything but rice burners and...and tubas, of course. (Electronics engineers refer to the taper concept as "impedance matching" - a physical reality in waveguide design...But, I digress.)
P.
Old 04-27-2010   #4
FR,
"I find all this talk rather interesting. On my Stingray, I have SPD build a choke into my collectors on purpose. This one is identical, Divergent & Convergent angles, to the ones on my Stingray, I just have an extra set for dynoing only as the ones on my Stingray are welded to the exhaust."
It's clear that the choke illustrated by your header collector is gradual and represents a single point. My constriction, OTOH, is more abrupt and significantly longer length. It just doesn't make sense to me that this isn't affecting performance coming from the left side of the motor. I'm willing to listen since addressing this is gonna cost a few bucks to eliminate.
Old 04-27-2010   #5
flyin ryan
flyin ryan's Avatar
I understand your system. Just don't know if there is as much in it as one may think or want to believe. The majority of the exhaust gasses are concentrated toward the center of the pipe & gradually diminishes' as they approach the wall, so how much of that exhaust gas volume is being affected...maybe 5%? Of coarse all this depends on pipe diameter being discussed for a given combo too. I've mentioned on here in the past my thoughts about exhaust sizing on our cars (Way, Way too big on average) but don't say too much as to not have the entire community hate me, LOL. The collector I showed might surprise some guys the size it is versus the HP it supports. I'm actually contemplating a little smaller set. So bottom line, don't think I'm trying to discourage, just trying to shed some light on the situation. To physically & visually look at your exhaust, the obvious answer is to automatically assume it is a problem, I mean how can it not be?...but may not be so much in reality.
Old 04-27-2010   #6
tpepmeie
Right on, FR. In fact, a 2.5" diameter choke would not be unexpected for my 700 hp engine. Recommended, in fact. There is a relationship between primary pipe size, and length to the choke size, too.
todd
Old 04-27-2010   #7
todd
Todd/FR,
Thx for the input. Could expand on the relationships you are discussing?
If I am understanding FR, you are saying the bang for the buck isn't there in removing the constriction.
Old 04-27-2010   #8
jonszr1
jonszr1's Avatar
i not to long ago posted the difference between the 21/2 in corsa and thew unique 3 in system my kids came up with . the car with the corsa the car with the corsa went 12.71 114.77 with the change over done between rounds on the same day at fointana the car went 12.23 .@116.40 the 3 in they came up with had a unique dual crossover witch was a 3 in wide by 3 in deep reqtangular pipes that look like 2rulers done at the area where the pipies bend to go down the tunnel . they then put in 2 21/2 in super turbo mufflers. they then changed to 3 in super turbo mufflers and found that the et got better but not the mile an hr . hopefully i can get to bill boudreaus house to take some pics to show what they did . all i can say is this exhaust makes more poiwe than the corsa and is even quieter than the corsa also . i do believe that it is the best of both worlds unless one wants a very loud exhaust . i will say i dont like the collector that stainless works puts on their headers
Old 05-08-2010   #9
Took a trip to Brakes Plus yesterday to "address" the constriction issue, thanks to Al. Seems like when there's some work to be done on a ZR-1 in Chicago, some of the luminaries show up. Low and behold, Pete comes over to mount some Nitto's on Kevin's car for BG. Paul Workman showed up also. Helpful that they were there to lend a hand. Completely impromptu on an FBI Friday afternoon. Besides the narrowed header pipe, we also tacked the muffs. They'd rotate when the motor torqued over giving them a cockeyed look.
The piece we eliminated comes from Magnaflow. The system is meant for a stock exhaust LT-1/LT-4 motor so it makes sense but not for the LT-5 with headers. Here's what it looked like:
The OD of the pipe was 3", while the ID was 2.75". However, there it slipped over onto a 2.25" inner pipe that was attached to the female ball flange. We replaced all of that with a 3" female ball flange which slip fit into the swedged portion of the original 3" portion of exhaust pipe. Al then welded it.
Old 05-10-2010   #10
Like to see a pic if possible Jon.
Tags
narrowed head pipe, restricted exhaust
