#11 |
![]() Join Date: Jan 2009
I know that I would not run out and buy a new battery just yet.
I'd check the battery connections first. Then I'd give it a good charge.
#12 |
Last time I saw a SYS light the INST fuse was blown. Replaced fuse SYS went away.
#13 |
![]() Join Date: Dec 2007
Had limited time this evening. Found out that the SES light doesnt work at all. Pulled codes an got a C41. Battery held 12.6 volts all day so battery is good. Will do more looking in the morning.
#14 |
![]() Join Date: Dec 2004
according to my 90's FSM a 41 = wrong or bad MEMCAL.
#15 |
I think MEMCAL is FSM-speak for "chip" or EPROM or PROM ( not the senior prom either
#16 |
It was a C41 code read from grounding the G & A terminals and displayed on the speedo not the SES light is that still the correct reading? I have a FSM but am having a hard time finding the codes in it ...
#17 | |
![]() Join Date: Jul 2007
EBCM (ABS ECM) AC controller and Radio also connect tot he Serial line
#18 |
Sorry, my bad
![]() I've never been in the 8D section of my FSM. You should see how clean the pages are. Your page is 8D-47, near the back of the thick book that has "Service Manual" on the cover. It's not the supplement LT5 book or the Electrical Book. I do not have a scanner on my P/C so I can't send you the pages. The opening step of the diagnostic chart is not very involved. I can write it in a post if need be? ![]() Tom
#19 |
Okay this morning I removed the stereo head unit that was repaired this winter and the sys light is gone. -=jeff=- is going to borrow me a spare and see if that is the problem.
Also am going to try a different ECM to see if that helps the SES light issue. |
#20 |
okay got the ccm out this morning, checked data link wire. Have signal between aldl ,ccm, heat /ac controler and brack ecm. no signal at ecm, Going to check for open or ground next
