Does anybody has a software or know how to change the original set-up of the signal which runs from the transmission to the ECM/CCM?
As I've changed my rear end to another ratio, I'll need to modify my present system for correct MPH reading. I know there are some additional convertors/gear sets on the market, but I would prefer to alter the existing software if possible. If somebody might have an idea, would be great! Thanks Thomas |
Only thing that is available is the speedo correction box, which you splice into the existing wires and program it.
Thanks Jeff,
could you recommend any supplier/manufacture or doesn't matter? Thanks Thomas |
Sorry to dig up this old thread...
My question is to Jeff, Have you used the Cyberdyne box? If so how well did it work? I just changed to 4.10 gears and bought a Cyberdyne box. When I hook it up, the speedo just sits there at zero and eventually the "service engine soon" light comes on. When I remove the box all is OK. I'm calling Cyberdyne in the morning. Any thoughts? H ![]() |
Why wouldn't you change speedo gear in trans?
![]() When I installed a ZF-6 in my 84, I also used 3.45 gears in rear. Just need right combo of drive and ring gear. |
![]() Join Date: Jul 2007
I would get the gears from Haibeck.. for the trans and be done
Gears are $120 from Haibeck not to mention the labor involved. The Cyberdyne calibration box was $49 and is precisely adjustable. (assuming I can get it working)
H ![]() |
you might give bill boudreau a call he did one for me on my white car when we did the clutch and tranny .
