02-24-2010 | #1 |
Whats going to go out first,master cylinder or slave..............
For the clutch?
02-24-2010 | #2 |
Re: Whats going to go out first,master cylinder or slave..............
Either.....I would do both as a set. Did both on my 90, only did the master on the 92 and noticed that the clutch engagement is not right, will be doing the slave this spring.
02-25-2010 | #3 | |
Concur. I suggest doing both at the same time just did mine. I bought my clutch master cylinder from these folks at Ebay auction #360224585374 The part was made in the UK. Works great and a good price. I would ask them if they have any more. Daryll
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 02-25-2010 at 01:46 AM. |
02-25-2010 | #4 |
How much of a pain is it to get to the rod thats connected to the pedal?
02-25-2010 | #5 | |
The knee bolster has to come down, mind the wires to the ALDL and the foot well light as they are a bit short. I usually get all the screws out, 7mm bolt heads, drop the panel and then take out the bolt for the ALDL, and then pull the connector on the light. I don't remember how many 7mm bolts in the bolster, maybe 7 I think. There are three up at the wrap around part by the side of the bolster, they hide in the fuzzy carpet. Three more on the face just under the dash edge, and one down in the very end where it turns from carpet to plastic, that one is in a recess and is almost centered in the panel. I pretty sure they are all 7mm heads. It's been a while, sorry. I'll get to do this, again, as soon as my set arrives from rockauto.
02-25-2010 | #6 |
What Tom said. Anything under the Hush panel areas of either side of the beast in short, is always going to be a pain or a PITA if you prefer. Its not required but I would suggest pulling the seat makes life a whole lot easier to work under there. 4 Nuts, couple of harness plugs and you have plenty of room under there to work. Well plenty is subjective you have "more" room to work under there
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 02-25-2010 at 09:00 AM. |
02-25-2010 | #7 |
Ive had the hush panel off for the brake light switch.I dont need to replace the master-slave just yet but want to get to it before they go.The trans gets funny if you hit 3rd gear hard,Ill replace the trans fluid before I change out the other parts.Thanks all for the info.
02-26-2010 | #8 |
not wanting to tell you what to do Jeff, but it sounds like the pair should be done sooner rather than later Bro.
The going into 3rd on the funky side seems to be the tell tale generally. Tom
02-26-2010 | #9 |
Thats what Bill B told me when I asked about the fluid for the trans.now,Ive got limited space in my garage.If I remove the rear inner wheel well panel will that get me more access to the slave cylinder on the bell housing?I havent takin a look under the car yet,just started looking into this job.The cars got 14,000 miles but is this an age issue opposed to miles?
02-26-2010 | #10 |
Yes time can be just as damaging as wear even more so in some moist climates and very dry climates. Even Dave M said to drive these cars. If you dont stuff will start to break, leak and fail. Do both master cyliners if only for piece of mind. According to the ZFDoc a bad slave will kill a healthy trans fast.
