View Poll Results: Have you ever hit the rev limiter? | |||
YES |
147 | 67.12% |
NO |
72 | 32.88% |
Voters: 219. You may not vote on this poll |
Thread Tools | Display Modes |
#41 |
Unless your torque and Hp band has changed extensively from stock, you are needlessly damaging your engine by hitting it ESPECIALLY ON EVERY GEAR SHIFT! If your engine is stock, than you aren’t even getting the benefit of better track times, you are going SLOWER.
You know now that I think of it, even if your engine IS modded hitting the limiter cuts fuel and sputters the engine, taking seconds off of your end time. My advice would be to shift earlier than the limiter, there just is absolutely no benefit, while creating a healthy chance for a potentially catastrophic failure..... Why?? ![]() But I must admit, I like your attitude much better than those who keep garage queens... Unless you are just filthy rich and have a collection of course.... But I would still drive the nuts out of a different one each day. Oh ya and limiter in 5th gear, I couldnt bang it and I was on a very very very long straight part of I-5 in central CA. just had it WOT for some time, got up to about 182 or so, its scary to look away from the road for more than a nano second. And it took an eternity (probably just 15 seconds or so) to climb even one MPH. So Im not sure you can really hit that sucker with a stock motor. I wonder what the top speed of 5th gear is mathmatically (i.e. in a drag less setting). Anybody? |
#42 | |
#43 |
But of course even before you hit 205mph and the limiter, your alternator will be generating the needed 1.21 gigawatts and then who knows where you'll end up,... or when you'll end up.
#44 |
![]() Join Date: Aug 2005
Yep hit while drag racing. Running GSC's and spinning the tires in third gear. If it would hook up I would probably break something!
#45 |
![]() Join Date: Dec 2003
never hit mine yet but i think my chip has it at 7400 now..I shift at 7000 and it gets to abt 7200 buy the time im done! Works for me! Im am at the point now I can tell the rpm by ear. I was going to get a light but my ear can now tell me when to shift. Took a while on the lt5 compaired to other engines to get a tuned ear for the rpms cause she pulls so hard for so long but afer a couple of years now and some practice I have a handle on it!!! I dump the clutch at 3k for launch and it spins the tires just a bit all the way through first, squaks into second and chirps into third....gotta luv my new chip and alum. flywheel and race clutch, b4 the best was a chirp into second only!!! Now she snorts they way we like it! I dont dump it too often (only to show off to friends mostly) since we all know abt the weak link of the u joints!!! and if u dont have driveshaft loops installed well.... i do have to say the gear rattle is quite noisy and it took a while to get used to it(actually u never really do) and it is a bit funny when people first hear it(they think ur tranny is broken) but once u hammer it they soon figure that it must be ok and healthy!!! lol
#46 |
![]() Join Date: Feb 2006
TOMTOM72:
With a stock chip in my 91 the shift light will light in any gear except sixth if you hold speed for a while. Cruising 70 mph in 5th for a few minutes at constant throttle it comes on. Change throttle position and it goes out. GM nanny wants to remind you not to waste gas and upshift. I never watch the light when I'm hammering it so I don't know whether it goes on at the rev limit - too many other things to pay attention to ! |
#47 | |
![]() Join Date: Dec 2004
One thing though.........my secondaries should be really clean! I guess ya can't have everything, hugh? ![]() ![]() Tom
#48 |
my shift light is OFF
#49 | |
![]() ![]() Join Date: Mar 2006
#50 | |
