![]() Join Date: Oct 2007
Whats the procedure to remove the differential ?
Vince 90 red/red #1966 |
#2 | |
I just did mine and did not keep notes, but what I used as a guide beside other info I found searching the internet was this article. http://www.vetteweb.com/features/vem...car/index.html I had the actual magazine, but this will give you a good idea of the steps. The only thing is I used a rubber pad on my floor jack to release tension on the spring since I don't have a lift and definitely would not try the strap method used in the article. |
#3 | |
![]() Join Date: Feb 2009
http://digitalcorvettes.com/forums/s...ad.php?t=66382
![]() Join Date: Jul 2004
I will assume you have the exhaust off, the drive shaft removed and the driveline beam removed. (have fun with that)
you can drop it like this http://i.ebayimg.com/14/!BhO!mFwBGk~...QO5-Iw~~_3.JPG Or you can do it my way. I remove the toe rod ![]() disconect the sway bar from the rear knuckles. Then I pull off the spring, Be sure to keep the shims in the proper order as you remove the brackets on the back of the batwing you will see them keep them in order and together tap them to the bracket or the rear end as they are! Remove the spring from the left and right knuckles before you pull the center bolts out. I place a jack under the knuckles jack it up to take off spring tension and pull the nut off the long bolt and then you can drop the jack and the spring is free. I then remove the left and right knuckels dog bones(the ones conected to the frame towards the front of the car) The halfshafts from the rear end, Then the long brace that conects to the bottom of the knuckle and to the rear end, remove that one by pulling the two bolts from the bracket leaving the large bolt with the washer conected to the bracket http://i.ebayimg.com/11/!BglIy7QBmk~...p8-,w~~_35.JPG You see the shocks are removed in this pic but you can remove them from the knuckle and leave them bolted to the frame same system as pulling off the spring. ![]() Now all you should have left is the rear end with 2 bolts connected to the frame, I use a tranny jack or a regular jack under it unbolt it and lower it down, then you can seperate the pumkin from the bat wing.
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
