10-15-2009 | #1 |
Life is good.
I just get this beatifull Z's top end back together and it's running great. A coworker and I go to lunch in it and the alternator freezes up. Luckily it happened right in front of a customers shop we do work for. Oreilleys says the will have a rebuilt one ready to pick up at 4:30 today.
10-15-2009 | #2 |
Re: Life is good.
You right , Life is good.
Much worse could happen.
Frank Urbo. NCM Lifetime member # 982 Registry Founding # 237 |
10-16-2009 | #3 |
Re: Life is good.
so when are you going to begin the frame off restoration? Hehe....good news man....any seat of the pants difference? You aren't going to have it tuned until the exhaust is done right? How about a mail order tune in the mean time?
10-16-2009 | #4 |
Re: Life is good.
he has a tune from me that is a copy of my black car. the only diff is i have jeal headers and a dr gas exhaust. the tune might be a tad rich till he get headers. my car made 419 rwhp and 383 tq on coreys dyno .his port job is a dead on copy of the black car also . no need for him to spend 400 on a dyno session .for max of maybe a 5hp gain . i gave him a copy of my prom .hope this helps
10-16-2009 | #5 |
Re: Life is good.
rick ck your e mail
10-16-2009 | #6 |
Re: Life is good.
Rick, please do tell.
How does she feel? Did you yank the secondaries? Pete
10-16-2009 | #7 | |
Re: Life is good.
10-16-2009 | #8 |
Re: Life is good.
rick you might ck for a vacume leak. do you have a scan tool so you can ck the position of the iac and the tps.you can use a propane torch with a hose on the nd of it run ti over you vac connections if you have a leak the idle will go up .hope this helps . the idle on that prom is set for 900-950 due to the light weight flywheel in the black car
10-16-2009 | #9 |
Re: Life is good.
But usually when I have a vacume leak my vacume pump will cycle allot and sometimes go nonstop until I find the bad connection. But anythings possible.
10-16-2009 | #10 |
Re: Life is good.
might be your pvc system or maybe your brake booster . my cruize control caused a high idle in the blk cvar. va hose had a little leak
