10-12-2009 | #21 | |
Re: '91 Red/Saddle #1147
http://www.pnwzr1.com/brake_install.htm |
10-12-2009 | #22 |
So....with Jeffvette's brake adapters, I can install C5 calipers on my 1991 ZR1 as long as I have C5 rotors. I assume the C5 rotors are a bit thicker. The brake lines are the same? Does this apply to the rear brakes as well using C5 rear brake calipers (different adapters required)?
thanks
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-12-2009 at 04:58 PM. |
10-12-2009 | #23 | |
http://www.zr1netregistry.com/forum/...light=calipers |
10-12-2009 | #24 |
I did a search but was searching with the wrong words
Thanks again.....that information is exactly what I was looking for. Jeffevette suggests C6 vice C5 calipers and I am assuming the brake adapter is the same but rotors may be different. I have to do some more checking. |
10-12-2009 | #25 |
I went with Jeff's brackets and C6 calipers and rotors:
Stock C6 and C5 rotors have the same width and mounting but appearence wise they look different. Stock C5 Stock C6 Last edited by Jagdpanzer; 10-12-2009 at 07:25 PM. |
10-12-2009 | #26 |
Great information
Where did you find the C6 calipers and rotors? |
10-12-2009 | #27 |
From a buddy in Texas who had just bought a brand new C6 that he immediately had upgraded to a big set of Wilwoods on all four corners. Had less than 500 miles on them when I received them. Still haven't figured out what to do with C6 rear calipers and rotors he also sent.
Last edited by Jagdpanzer; 10-12-2009 at 11:07 PM. Reason: Corrected the spelling of Wilwoods |
