![]() Join Date: May 2008
Does anyone know of a source or suitable substitute for the small...about 1" X 1" X 1"...foam filters, up near the front, in each one of the cam covers? They are located where the metal air pipe connect to the cam cover. When I removed my cam covers and touched them they crumbled and collapsed in place...most likely due to engine heat and age.
Looking for a substitute, I went to several hardware stores, a couple of auto parts places, a lawn mower parts house, Home Depot and Lowe's. No one seems to have anything close. |
I need those things too, mine were hard as rocks and crumbled at the slightest touch. Hopefully they can still be purchased somewhere, or at least a suitable substitute found. It's just a really, really coarse sponge.
Cut up a strip of scotchbrite.
#4 | |
![]() Join Date: Nov 2007
I use copper scrub pad will not cumble break down or soak with oil.Cut to size and your ready to go. AL. |
Good suggestion, I didn't think of using that. I'm gonna try it, thanks! Jeffvette, your suggestion sounds good too, but can you get scotch brite that is 1" thick? Plus, seems like it wouldn't be coarse enough.
Probably need to get the 3M commercial "doodlebug" stripper pads, they come in various textures, about 4" by 8" size so not too pricey.
Can you post a pic of these filters...in situ
Thanks |
Ditto can somebody post a pic of were these are located on the car for the benefit of the group? Thanks GC
#9 | |
Under side of the cam cover, the filter to be changed is here... ![]() Held in by a little wire, bent over to hold it in place... ![]() Outside - finger pointing to where the tube inserts into the cam cover. ![]() (Pardon the look of my covers, but they're going to be painted here in a week or so. ![]() P. |
#10 |
Ahh..so only way to replace is to remove the cam covers. Thanks Paul for posting the pics...did not know about these guys
