Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 08-09-2009   #11
Jeffvette
Default Re: Crank Shaft Rear Seal Replacement Get Together
Originally Posted by flyin ryan View Post
Where does Marc H. get his glass springs from, you guys know? Vette Brakes maybe? Always found there stuff to be great, either Corvette or Camaro F-Glass springs.
I believe the spring he had was a take off from Dwight's car.
Old 08-09-2009   #12
Scrrem
Scrrem's Avatar
Well got a real education today. Watching the pros...man they made this job look easy. Thanks for the schooling guys... Here's some pics of the seal replacement......
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 08-10-2009   #13
Don't ya just love it when a plan come's together ? Nice job !
Who's the guy with the fuzzy arms ? Look's like he has a sweater on
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 08-10-2009   #14
QB93Z
QB93Z's Avatar
It was a great Get Together. Many thanks to Darrin, David, Phil, Rich, Glenn, and Don for helping me get this job done in a timely fashion.
Special thanks to Phil for his expertise. You taught us a lot my friend.
Flywheel is out, crankshaft seal housing is removed:
Removing the transmission rear seal with appropriate supervision:
I will post some items in the technical section about what we did.
Old 08-10-2009   #15
QB93Z
QB93Z's Avatar
Yea, we were wearing sweaters because it was only about 98 degrees in the garage yesterday.
Old 08-10-2009   #16
Scrrem
Scrrem's Avatar
Man, those two supervisors are doing one hell of a job making sure the work crew gets that transmission seal in there straight
Rich
Ron Davis Radiator
Old 08-10-2009   #17
QB93Z
QB93Z's Avatar
Hey Rich,
I am glad you made it up to help out.
And Darrin says he would have found that bolt on his own.
Old 08-10-2009   #18
limey
Looks like to me you're missing the rear drip tube, did you already take that out?
If this is missing, you can bet that the oil is leaking from your PCV baffle and dripping through that hole.
limey is offline   Reply With Quote
Old 08-10-2009   #19
QB93Z
QB93Z's Avatar
Kurt,
The drip tube was removed with the Seal housing. Thanks for checking it out.
While it was removed we did a clean out of the valley drain.
Even with the drip tube in place, I could still have a PCV problem as Pete pointed out.
Old 08-11-2009   #20
Scrrem
Scrrem's Avatar
Originally Posted by QB93Z View Post
Hey Rich,
Yeah, he says that now....but you did see him start reaching for that big A$$ pry bar
Rich
Ron Davis Radiator
