Old 05-08-2009   #1
rkreigh
Default c4 exotic muscle coil overs
I have a complete set of coil overs with red powder coated springs
I believe the spring rate are 425 front, 300 rear
complete with the modified FX3, controller box, and actuators
$1400 complete
I'll bring these to BG if I have a serious buyer but don't want to haul them down there if no one is interested.
thanks!
Old 08-05-2009   #2
ajs94lt1
Default Re: c4 exotic muscle coil overs
Curious if youve sold your coil overs.
Thanks
Ajay
ajs94lt1 is offline   Reply With Quote
Old 08-05-2009   #3
rkreigh
still for sale Ajay
I can bring them to carlisle if interested
Old 08-05-2009   #4
ajs94lt1
Not being so familiar with the part numbers and codes, perhaps you can answer these question....when you say Modified Fx3....is that the actual shock? Would it be the same ones I have in my 94 with the adjustable shocks? Also, the controler and actuators....thats the mechanism that does the actual adjustting along with its conroler. If so....thats a super deal since those parts cost an arm and a leg if one goes bad. (try to get a tire pressure sensor...that will double kill you). Anyway, thanks for the response and let me see if I can swing that amount.
Ajay
Old 08-08-2009   #5
rkreigh
Ajay
Hi ajay
the stock (91) fx3 shock has a groove cut in the body to allow a snap ring to secure the coil over hardware, so it's a stock fx3 shock actuators go on top of the shock and does the fx3 shock positioning
this stuff will work on the later model cars as long as you use the correct controller (comes with it)
yup, I think it's a good deal too, let me know if I can answer any questions
