Old 06-22-2009   #1
rudolph schenker
rudolph schenker's Avatar
Default Pump cycling with key on???
I'm a newbie, so this is probably a dumb question.
With the key in the on position (engine is off) a pump cycles on and off every few seconds. Is this normal? Is it the vacuum pump? Should it only cycle once before starting? Any info appreciated. Thank you.
rudolph schenker is offline   Reply With Quote
Old 06-22-2009   #2
flyin ryan
flyin ryan's Avatar
Default Re: Pump cycling with key on???
Should cycle, but not every few seconds...must have a small vacuum leak. Would be the 'Secondary' vacuum pump. Not 100% sure what normal would be/is... , 30-45 seconds anyways. Lots of info on this subject around.
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y.
Old 06-22-2009   #3
flyin ryan
flyin ryan's Avatar
I should mention..., the secondaries will still work fine. The pump is really an 'Auxiliary' pump, when it cycles it's more annoying than anything else
Old 06-22-2009   #4
rudolph schenker
Yes, car runs fine, it is annoying though. Where are common leaks found? I'll start checking, where is a good place to start?
Old 06-22-2009   #5
If the pump cycles on and off every few seconds or it runs continuously, chances are, you have a vacuum leak somewhere in the system.
All you need should be covered here
http://www.corvetteactioncenter.com/...cuum+Diagnosis
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg
http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif
"The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC
" We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln
Old 06-22-2009   #6
jonszr1
jonszr1's Avatar
ball ck valves are a common thing that goes wrong . but ypu need to pull the plenum. its an easy job .just ask most of us we all havew done it a few times .do you have a fsm?
Old 06-22-2009   #7
Sgreg
Sgreg's Avatar
Ck the long lead hose that goes from the pump to the plenum. Particularly the fitting at the plenum. If no leaks at the pump or at the plenum you will become the umpteenth member of the pull the plenum club !! Lots of things to check under there.
1991 ZR-1, Black, Black, # 541
Sgreg is offline   Reply With Quote
Old 06-22-2009   #8
Ccmano
Ccmano's Avatar
I wouldn't get too excited about it. The only time it is even noticable is when the key is on and the engine is off. Unless it runs almost continuosly or the secondaries aren't coming on there is really no need to go to the trouble of pulling the plenum to fix it.
If you do, you might as well change out the coils, wires and injectors as preventative maintainance. Otherwise it's not worth the hassle.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 06-22-2009   #9
Jeffvette
Start with the easy section first. The line between vacuum pump and the connection to the vacuum spider (It's by the oil filter). After that, it can be a number of small things. But it's best to pull the plenum and assess everything underneath.
What is your interval of the pump running?
Old 06-24-2009   #10
rudolph schenker
Cycles only for a second then turns off for 5 sec. The line to the plenum is fine. I figure there is a small leak under the plenum and I will have to pull it. The secondaries work fine. Could somebody give me a list of things to do with the plenum off and cost of repacing some items?
