Old 05-26-2009   #1
Aurora40
Aurora40's Avatar
Default Update: Installed the oil catch can...
I bent the stock PCV rigid line so that I could attach a catch can without the can pulling on the F-piece or the dual-connector thing up front. Now all I have to do is get an actual catch can! I'm thinking about that CCA one just because it doesn't seem to be too large or anything, and it may mount up nicely on the brake booster.
Edit, also, man are those GM coolant pipe gaskets crap! Mine are maybe 2-3 years old. The bolts were all wet and corroding again. Plus the gasket didn't survive removing the hose. I've ordered some Jerry's ones to replace them on both sides, I'm sure the other side is all crapified as well.
Edit later: See update on post 29
Old 05-27-2009   #2
Default Re: Ready for the oil catch can...
I like my Elite Engineering Can
Old 05-27-2009   #3
Aurora40
Aurora40's Avatar
What is that mounted to? Did you have to add holes to the wheel liner?
Old 05-27-2009   #4
Yes I added 2 holes to the wheel liner
look in the bottom right corner, the darker 2 bolts are what hold it in
Old 05-27-2009   #5
1990 415
nice install. the powdercoat is beautiful. that color just pops. Jeffvette outdid himself again.
1990 415 is offline   Reply With Quote
Old 05-27-2009   #6
How does it drain?
Old 05-27-2009   #7
jonszr1
jonszr1's Avatar
i would bet there is a drain at the bottem
Old 05-27-2009   #8
How does it drain?
the bottom of the can is basically a cup. it just unscrews and then you can pour the oil out of the 'cup'
there is no drain valve on the bottom
Old 05-27-2009   #9
Can you grap a pic of that Jeff? I would like to see it. Thanks GC
Old 05-27-2009   #10
yeah, if i remember.. LOL
here is the website for it
http://www.eliteengineeringusa.com/Catch_Can.html
