Old 05-15-2009   #1
HADI-ZR1
Question Fidanza Clutch Kit for Zr-1 !?!
why i should use Fidanza FIVE Point FOUR Clutch Kit - GM Corvette ZR-1 , which is for race, and it say USE with Stock Flywheel.
But for Fidanza TWO Point ONE Clutch Kit, which use for light Mod. Lt5, it say USE with Findanza Flywheel.
It is strange. any one know why? the fact!
Old 05-16-2009   #2
Default Re: Fidanza Clutch Kit for Zr-1 !?!
Hadi,
I would direct the question to Fidanza. I just happened to be looking for a clutch for my Fidanza aluminum flywheel and here is some information from Brad at Fidanza:
Hey Craig,
> Thanks for contacting Fidanza. Here are the
> part numbers and torque specs:
> #391841 424 lb-ft.
#391842 589 lb-ft.
#391843 702 lb-ft.
#391844 665 lb-ft.
> The clutch should be balanced with the flywheel
> as an assembly. Also, you should use a sprung hub clutch
> disc (all of the part numbers listed above except the 391844
> are sprung hub). Doing both of these will help eliminate
> some of the clutch chatter that you may
> experience.
> Thank
> You,
> Brad
> Bojc
> Fidanza Engineering
> Corp.4285 Main
> StreetPerry, Ohio
> 44081
> brad@fidanza.comwww.fidanza.comAIM:
> FidanzaSVT
> Phone: (440) 259-5656
> x111Fax: (440)
> 259-5588
Old 05-16-2009   #3
carter200
carter200's Avatar
great info Craig
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 05-16-2009   #4
This is what I did
http://www.zr1netregistry.com/forum/...66&postcount=3
http://zr1netregistry.com/forum/show...+clutch&page=2
-- very happy --- where the heck have you been HADI?
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg
http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif
"The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC
" We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln
Old 05-17-2009   #5
HADI-ZR1
Thanks Craig. and Bryian for info.
i am bussy all time brother..life!
no worry, i am here around some times.
after to weeks i am going again to Russia.
hope i find new chiks there!!
Old 05-17-2009   #6
HADI-ZR1
So what is the best clutch can be used with Fidanza Flywheel??
and what stage for 500+ hp LT.5 , if any known !
Old 05-17-2009   #7
Kb7tif
On my fidanza set up i stayed with the stock clutch/pressure plate.
Very little noise ect.Works great.
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Old 05-17-2009   #8
Well you can stay stock like KB7TIF did or you can go race with a ceramic like I did with a Carolina setup. If ou are interested in the race setup just email the boyz at Carolina and they will get you all set up with a turn key package like they did me. My clutch was shot and I wanted a performance one so I went ceramic. I like it very aggressive however -- super tight grip action!
I went stage 3 for my 92 Z
http://www.carolinaclutch.com/Conten...te-lt.htm.aspx
http://www.carolinaclutch.com/showitem/108823.aspx
http://www.carolinaclutch.com/ShowIt...0Flywheel.aspx
http://www.carolinaclutch.com/ShowIt...olt%20Kit.aspx
We will look fwd to your adventures in Russia -- Are you going to drive the Z there?
Old 05-17-2009   #9
Hadi,
Best wishes in your quest for the ultimate clutch. I'm in the same boat and looking myself.
Bryan,
Thanks for sharing and the price sure is attractive as over $200 less than the same offered in Fidanza from Carolina Clutch.
Old 05-17-2009   #10
HADI-ZR1
Hey Bryan, is that corvette use same as your Setup??!
http://www.youtube.com/watch?v=0jqyc5x1YhY&NR=1
This setup is very hot!! be careful when watching it, it could change your mind.
, maybe Stage 4 ?! i wish test shifting her !
http://www.youtube.com/watch?v=xpS7M...eature=related
