Old 04-18-2009   #1
Default Dielectric grease
O.k. D-day minus one.
Tomorrow I am pulling the plenum to seal vacuum lines and replace fuel injector.
When reconnecting electrical connector, would you recommend dielectric grease (jell). Is this to keep the moisture out?
Hoes this stuff conduct electricity?
I normally use the stuff around the spark plug boot. Same stuff?
Old 04-18-2009   #2
lbszr
lbszr's Avatar
Default Re: Dielectric grease
There should be a seal to keep out moisture but I thinks they can fall out. I don't remember GM calling out to put anything on the connector.
Dialectric grease actually is nonconductive instead of a conductor, it only prevents corrosion, if it's already corroded the grease won't help with connection.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 04-18-2009   #3
I saw a post where someone was recommending some kind of jell/grease for connectors under the plenum.
Old 04-18-2009   #4
May have been me. I recommend a light coat of silicone grease on the connection and the rubber weather seal. It aids in resistance to corrosion & the seals ability to keep out moisture.
Also good on weatherstripping to keep it "fresh".
Old 04-18-2009   #5
Thanks. I will takr your advice.
Old 04-19-2009   #6
flyin ryan
flyin ryan's Avatar
I always use dielectric grease whenever possible/applicable. Never hurts
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y.
