![]() Join Date: Mar 2007
Well the good news is I fixed the Vacuum leak....the bad..I am getting the no start. I originall ythought it was the battery, once replaced the car started right back up. Then this week with the new battery I go the no start again. The battery is showing 3.68AMPs and 12.42 volts when tested with a Fluke meter.
I notice that when I push in the clutch there is a volt drop...but not sure that means the Clutch relay is working or not. I am guessing starter, any other guesses? Ignition switch?
1. Jumper out the Clutch safety switch.
2. Replace Starter relay under dash. 3. Install my patented "Dreaded No Start Cure". ![]() TomC "Crabs" |
Would I be seeing a voltage drop when I depress the clutch if the relay/switch was bad? Car started right back up when I went out again.
Any opinions.....
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 03-22-2009 at 09:25 PM. |
![]() Join Date: Jul 2007
![]() Join Date: Feb 2006
Had the dreaded no starts 2years ago and did "tccrab" Dreaded No Start Cure and have had zero no starts! Thanks Tom!!
![]() Join Date: Jul 2005
i believe if you are getting voltage drop you are ok .tto double ck work the clutch in and out while having the key in start mode. i found thatmy floor mat had bunched up once and couldnt press the clutch in far enough to activate the switch
Just got my floor mats tonight, so not the issue.....trying to get someone to tell me if the volt drop when I depress the clutch pedal means anything? To me it would mean the relay is working....but not sure,looking for feedback. I guess Jeff is saying it does not mean that the switch is working.
#10 | |
