Old 03-20-2009   #1
Default O-rings
What is the part number or alternative part for the fuel injector O-Rings.
Old 03-20-2009   #2
Ccmano
Ccmano's Avatar
Default Re: O-rings
Give Don (KarterDon) a call, he has them. Just bought a set today. $1 apiece.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 03-20-2009   #3
Default Re: O-rings
17112222 Seal, Fuel Injector (o-ring) (upper @ rail) 24 req'd $10.80/set
10067600 Seal, Fuel Injector (o-ring, primary) lwr in inj hsg) 8 req'd $6.00/set
I have them.....
Jerry
Old 03-20-2009   #4
Polo-1
Default Re: O-rings
Hey Jerry do have the o-ring on the front of the crank, for the oil pump.
Old 03-20-2009   #5
Default Re: O-rings
Yes I do. The set contains 4 o-rings. They are show in the engine assy drawing for Oil Pump, Pan and Related Parts, as itens # 427, 443 & 444. Here's the web link for the o-ring set ...
http://jerrysgaskets.com/store/index...products_id=28
The web page shows the individual seal GM part no's, which are the same numbers I use.
Jerry
Old 03-21-2009   #6
Polo-1
Default Re: O-rings
maybe I have a old # ?
10067685
Old 03-21-2009   #7
Default Re: O-rings
10067685
That PN is for the Seat, Oil Pump Seal, which is the steel "washer" the face of which is the opposing part to the carbon oil pump seal.
10135870 is the PN for the Seal, Oil Pump (o-ring) that goes on the crankshaft first, in the groove immediately in front of #1 main.
The set I sell is for all 4 o-rings related to installation of the oil pump. I have the OEM carbon seals too, sold separately.
Hope this helps. I can take a couple of photos if it helps so you can get the parts you want.
Jerry
Old 03-21-2009   #8
Polo-1
Default Re: O-rings
I just can read the fiche
Old 03-21-2009   #9
Default Re: O-rings
The pdf source I used for PN's is not very legible, so it wouldn't surprise me at all if I had mistakes in PN's.
Let me know if I can help.
