Old 02-04-2009   #1
kenthompson
kenthompson's Avatar
Default Ignition channels
So, I'm installing the MSD DIS-4 on the car, but I need to know which channel is which.
Does anybody know if channel 1 is coil 1 and so on, as listed in the FSM?
Does it matter?
KT
1990 Grey/Black
Too many for the sig.
kenthompson is offline   Reply With Quote
Old 02-04-2009   #2
Default Re: Ignition channels
I don't know if this will help. I looked in the electrical section 8A book and this is what I found:
Coil 1 = 1 yellow ckt 933
Coil 2 = 1 Dk Green ckt 934
Coil 3 = 1 Dk blue ckt 932
Coil 4 = 1 Orange ckt 926
The above are wires going from the "Distributorless Ingition Module", but where they are going to is where i get lost as I sure don't understand how to read the diagrams...sorry.
Old 02-04-2009   #3
Not sure what you mean by "channels" and I'm not familiar with MSD DIS-4,
but our ignition system is "waste spark". Pairs of cylinders are fired, ie 1-6.
The FSM will show the pairing.
Old 02-04-2009   #4
Does it matter?
KT
just looked at the User instructions for the DIS-4.. It does not seem to matter on the correlation of Channels to Coils.. BUT be sure the matching input and out put wires are used on the same coil.
So now I have to pose the question, what is the reasoning behind adding the MSD? you looking for improvement of sorts or??
Old 02-04-2009   #5
The instructions seem to indicate the MSD unit between the PCM and the coils. I am assuming in the case of the LT5 that means between the Ignition Module and the coils.
I'll second Jeff's question on the need for the MSD unit. I'm not being skeptical, just curious.
Old 02-04-2009   #6
Correct between Ignition Module and Coils
Old 02-04-2009   #7
kenthompson
So the firing order wouldn't have anything to do with the channel lineup then? I guess it would depend on the circuitry in the MSD unit. If channel 1 is independant of channel 2 for the capacitive discharge then it wouldn't matter.
As far as reasoning, two words: future improvements.
1990 Grey/Black
Old 02-04-2009   #8
kenthompson
And actually with the coils adaptors from MSD, no wires have to be cut in the factory loom to install the MSD unit. I can take it out any time I like.
1990 Grey/Black
Old 02-04-2009   #9
kenthompson
Right that's what I found too. Same type of thing in my corvette fuel injection book (only some of the coils to cylinders are different)
But I didn't know if coils related to channels directly in the MSD unit.
1990 Grey/Black
Old 02-04-2009   #10
You have the PN for that harness by chance?
I don't think so or it would be specifically mentioned, I think the channels are independent..
Yeah, that MSD has soem nice features to go along with it..
Please post pictures when you tackle the install..
