A great article on C4 shocks and Selective Ride Control by Hib Halverson:
http://corvetteactioncenter.com/tech/c4/fx3/index.html |
Excellent read... now to a very basic question>>> the position of the gear (spline) at the top of the shock should be full counter clock wise or full clock wise prior to installing the actuator>>
#3 | |
Doesn't matter. When the key is turned to the "run" position the actuators find the end stops and set the shock in the correct position based upon the selector switch. |
Bingo... as usual Jeff spot on info
I know I eventually want to get revalved Moraca shocks...but has anyone here added the Z07 springs to a ZR1 with the moraca valving? I wonder how firm that would get. I've ridden in a stock 96 Z51 Grandsport, and I liked its ride, but as you know the Z51 GS does not have the FX3 shocks.
#6 | |
![]() Join Date: Jul 2007
I would suggest for a harder ride, do the shocks first, then springs.. 1990-91 Front Spring: 96.2 N/mm and Rear 39.9 N/mm 1992-95 Front Spring: 75.4 N/mm and Rear 33.0 N/mm GS Z51 Front Spring: 73.2 N/mm and Rear 33.0 N/mm Z07 Front Spring 115.5 N/mm and Rear 57.2 N/mm Although you could also just switch to coilovers with stiff springs the OEM spring rates I got from here: http://vettenet.org/susp_chart.html
