01-17-2009 | #21 | |
Re: How to calibrate the tac??
On my '90 the tach is also off by about 10%. I was thinking of just putting on a tach with the shift light and not worry about fixing the console tach.
Bob Anderson 1990 #2405 White/Gray Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported Minnesota State Director Founding Member #19 |
01-18-2009 | #22 |
guys do you know how the console tach is connected?
I dont think it reads the impulses from ecm because ECM reads good rpms. I checked it today with aldl cavble and datamaster. adn the tach shows almost exacly the twice rpm as shown on datamaster. so I thought maybe tach is connected to coil or coils and there is somewhere a short and tach reads impulses from two coils instead of one or something like that. |
01-18-2009 | #23 |
Rest assured that the error you're seeing is from "failed/failing" resistors/capacitors on the instrument cluster "main-board". Your confirmation is the "correct" output from the ALDL with your software.
Your location certainly doesn't offer a very economical solution to your situation. If you've an acquaintance here in the US you could arrange the repair from a facility here. The error you see I'm sure has increased over time. Minimal error when you first noticed or suspected it and it WILL become worse over time. Last edited by WVZR-1; 01-18-2009 at 04:54 AM. |
01-19-2009 | #24 |
I think I`ll get aftermarket tach and connect it on the electronic ingnition diagnostic terminal F, book says its instrument cluster tach input so then I will see if its the problem with instrument cluster or some wiring.
1991 zr1 convertible ;) |
