Need help with a vacuum leak, when I turn on the car but not start it the pump keep running, when I pull the one hose off the driver side of the plenum and plug it the pump stops. I tried to pull a vacuum on the plenum's connector but it won't hold a vacuum. any ideas?
thanks Mike ![]()
95- #338 |
![]() Join Date: Mar 2007
Are you testing vac off the P/S that is running from near the coolant overflow into the plenum? You should be able to hold vac if you plug your vac tester into the line running to the plenum. It should hold with slow leakdown at least.
If not there is a good chance you have a leak under the plenum. LGAFF 92 ZR1 #234 |
![]() ![]() Join Date: Dec 2004
If you can't hold any vacuum on the plenum side of the line you could see if you can find a vacuum check valve that fits the connector. Plug it into the line going under the plenum and re-do the vac test. If you hold vacuum upon the retest then you have solved the issue. There is a vacuum check valve in the hose network under the plenum that could have given up the ghost.
If that new check valve does not help, then the 2* control solenoid, reserve storage tank, maybe even the actuators or a leak in the actual hose are likely suspects. Unless you are setting a DTC61, I would say that the actuators are okay. To get an eyeball on what is under the plenum use this link. http://www.corvetteactioncenter.com/...ad.php?t=14272 some great stuff that gives a great explaination. ![]()
the vacuum is from the electric vacuum pump in the fron passanger side of the car. I check the hose from the check valve to the pump and they are fine, I wanted to check the connections on the outside of the plenum, when I remove the hose from the manifold vacuum (6e3-c2-6 fig c2-7 block #2) in service manual and pluged it, the moter stops, so I think the leak is between this connector on the plenum and where ever it goes, I just don't know where it goes.
I not talking from the connector to the check valve under the plenum I talking the other way from the connector on the plenum into the plenum ![]() Mike
95- #338 |
#5 | |
![]() Join Date: Aug 2008
Check valves don't give up the ghost. They just get dirty and clogged. There are actually two check valves under the plenum. One in the front and one in the back. Easy way to check it is to unhook it and block the single perpendicullar outlet with your finger and blow through the other two ends. It should only allow air flow in one direction. If you are able to blow air through in both directions then its got dirt in it. All there is is a little bee bee ball inside of it. Just take some carburator cleaner and spray it in all the outlets. Then blow it dry. Then take some WD40 and also spray it in all the outlets. Check valve will be as good as new. But hell what do I know. Also when it comes to secondary port throttle failure be suspicious of the secondary vacume solenoid. It has a little cheesy air filter on it and over the years will evetually get old and turn to dust allowing contaminents to get sucked up into it and cause it to fail giving you that "Run out of breath at 4000rpm''s old man caugh under hard acceleration (SES light)error code 61 BS".
Just stating the fact that there are two check valves under there. I never said they both affected the secondary vacum operation. But while he's under there he might as well clean both of them. Unless you never use cruise control. But since you are more of a ZR-1 genius than me you can help him out. I'll just stay out of it. Why should I care, as long as mine runs fine. Right!
![]() Last edited by rhipsher; 10-29-2008 at 02:11 AM. |
#9 | |
Whoa....... I just didn't want him poking around looking for a second check valve on the secondary system. I've seen people mention problems on a 90, which has a few different systems and people with later cars suggesting to check this piece, which the 90 doesn't have. The more info the better. ![]() |
#10 |
Wow, I think someone needs more sleep!
