#21 |
Did you talk to Jeff Flint AKA Jeffvette? $1200 is insane for a set of bolts!!!
#22 |
M14 x 1.5 x 220mm
#23 |
Parts book specifies 14X1.5X80
Can someone confirm this is the correct size head bolt? Do the factory LT5 head bolts have any special feature? Fastenal has 10.9 grade bolts listed in this size. |
#24 |
I can tell you it's NOT 80mm. Thats only 3.149 inch. The bolts go from the top of the head to the bottom of the block.
#25 | |
![]() Join Date: Dec 2003
Thread length is 62mm. Bolts must also have the flat ground, hardened washer. Obviously the washers can be reused, but if you have NO head bolts, the washers will be required also. Bolt head has an integral flange under the hex. I would imagine the prudent thing to do would be to send a stock head bolt to ARP to copy the configuration. I'll go so far as to say the result will be sticker shocking from ARP as well. It's a really big bolt.
#26 |
#27 |
![]() Join Date: Mar 2007
ARP sent a form to fill out, they want actual measurements including gasket material etc. They stated they may have otherbolts that match.
PDF file is too big to post here. I can't believe these frggin head bolts are more than I paid for a shortblock. LGAFF 92 ZR1 #234 I wonder what ACE hardware has in stock. ![]() |
#28 |
Stroker Crank.......... check
JE pistons................check Oliver rods...............check SGC Cams................check . . . . Made in China bolts to hold it all together......... ![]() |
#29 |
![]() Join Date: Aug 2006
yup...that's what you gotta have is the form. got a bunch here at all times, unfortunatly. the main measurment they will want above all else is U.H.L. (under head lenght). also, i always shoot for maximum thread lenght in(to) an aluminum block.
#30 |
![]() Join Date: Jan 2004
guys,
Ron and Randy Woods ZR1 Specialty Products make head studs that work just great they worked with ARP to design just the right stuff and are both cheaper and superior to stock give em a shout |
