10-13-2008 | #1 |
&%&$#@^ Oil Leak!!!
Noticed a small puddle under Girlfriend a couple weeks ago, finally put her up on jackstands to see where it was coming from.
I found 6 oil pan bolts that were only finger tight. 2 back by the flywheel and all 4 up in the front. I would up having to take off one of the 'K' brackets to get to the bolts in the front. Hopefully this cures the leak. Otherwise I'll have to put cardboard on the garage floor like my neighbor with the 1967 E Type Jaguar does... TomC "Crabs" p.s., Sure is dirty under there, gonna have to get out the cleaners and shine up the underbody!!
10-14-2008 | #2 |
Re: &%&$#@^ Oil Leak!!!
i had the same problem on both my cars . tightened them up and all was good . other thing that can cause a leak is the wrong washer on the drain plug
10-14-2008 | #3 |
They all work themselves a little loose over time. Good thing is snuggin them up usually takes care of it with no pan pulling required.
1990 ZR1, 142,000 miles-Black on black 4.09's Haibeck chip, 3"exh, K&N, meth inj. |
10-14-2008 | #4 |
10-14-2008 | #5 |
I read in the Registry Tech Section that I should have removed the offending bolts, cleaned them and RTV'd the threads before re-installing them.
Of course I read this after I had already put the K braces back. Did I omit an important step? TomCantStandOilLeaks "Crabs"
10-14-2008 | #6 |
i have zr1s and have just tightened the bolts . jeffs idea of taking 10 min to ck them is a very smart thing to do.its up to you on the rtv jmho
