Old 07-19-2008   #1
billybaloneey
billybaloneey's Avatar
Default Size Matters
A new owner here, so forgive these seemingly simple questions.
I know that the rear end body parts on the ZR-1 are bigger than the standard C4...to accommodate the wider tires.
1) are the doors a different size?
2) are the rear side light housings a different size?
3) are the brake and turn signal lenses a different size?
4) are the backup lenses and license plate assembly a different size?
5) is the rear end carpet and internal trim a different size?
6) is the "CORVETTE" script a different size?
7) within the ZR-1 line, 90-95, were there any parts that changed size/fitments from year to year? In other words will the early ZR-1 body parts fit the late model ZR-1's
Is there a list published anywhere that points out all of the differences between a ZR-1 and a standard C4...front to back? Obviously 75% or more of what's in the engine compartment is unique to the ZR-1. Other than the engine itself, what are some of the other items in the engine compartment that are ZR-1 specific?
Thanks,
Clint aka billybaloneey
'94 - C4 ZR-1 #445 - Black/Black
'05 - C6 silver/black 6sp
'85 - C4 white/graphite (almost done) automatic
'78 - C3 silver/black (a work in progress) automatic
billybaloneey is offline   Reply With Quote
Old 07-19-2008   #2
Default Re: Size Matters
1: yes
2: no
3: yes
4: yes, not a different size but a different assembly
5: no
6. from the normal C4 yes
7: not that i'm aware of other then the rub strip.
the ac compressor, rad, ecm, lines, belts...
this is all as far as I know, and i could be wrong.
Jeff you out there?
Old 07-19-2008   #3
Aurora40
Aurora40's Avatar
For #6 and #7, the "CORVETTE" emblem is larger on the '91+ models (of which non-Z's didn't have an emblem anymore). The 1990 has the same sized emblem as all '84-90 'vettes.
Bob Saveland
Former owner of #2517
Old 07-19-2008   #4
Originally Posted by Kevin
1: yes
2: no
3: yes
5: no
Jeff you out there?
You forgot to mention the "grin" is wider (on the ZR-1 drivers ).
P.
Old 07-19-2008   #5
I did not think the Brake and Turn Signal Lenses were a different size (#3)
Old 07-19-2008   #6
Default Re: #3
I never measured them to compare, but couldn't help but notice the proportion appeared to remain the same, in spite of the wider tail. So, I wondered if the ZR-1 lenses were not a tad bigger. Someday, I'll have a ruler along and satisfy/confirm what I suspected for some time.
P.
Old 07-19-2008   #7
Default Re: #3
P.
Guess I will look up the PN for any given year 91-95 and compare to the narrow body, but I am betting they are the same
Reverse light ARE different though
Old 07-19-2008   #8
32valvZ
32valvZ's Avatar
Brake and turn signal lens approximate measurements are the same on my 93 Ruby (LT1) and on my 92ZR-1 Tail light/brake lens are about 6 1/4" wide by 5" high on both cars. Reverse lights measure 3" wide and 6 1/2" on both cars. Rear side light/reverse lights are 1 7/8" high and 10" long on both cars.
As far as differences in body panels go (within the ZR-1 line), aside from the belt moulding, as someone mentioned, the front 1/4 side covers are different. The 90 stands alone. The 91-94 are another style & the 95 are also stand alone.
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 07-19-2008   #9
Jeffvette
Yes, the door line is different in about the middle. You can see it starting to bow out.
No, they are the same.
License plate frame (black portion) is different. The back up lights are the same.
No, the inner tub is the same. So the carpet is the same.
90 is smaller than the 91-95 CORVETTE emblem. But in 90 they were the same size.
Yes, everything will bolt right up, or I should say bond right up in certain cases.
