05-29-2008 | #1 |
" SYS " flashing next to fuel bars / mpg
What causes the digitial display to flash the letters SYS where it normally shows MPG? I noticed this morning it would flash " SYS " then go back to showing my MPG. It did this my entire drive.
any and all help is much appreciated. |
05-29-2008 | #2 |
Re: " SYS " flashing next to fuel bars / mpg
*UPDATE*, did a quick search and found someone with the same problem. I replaced my battery last night, i'm guessing the sys light will go out on its own .
05-29-2008 | #3 | |
05-29-2008 | #4 |
Sounds to me like your positive battery cable is not tight. I had the same problem from a loose cable. Removing and reconnecting the cable (tightly) at the battery will probably solve this one.
05-30-2008 | #5 |
This happens to me every time the battery gets low on its charge...
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int |
05-30-2008 | #6 |
light was out on my way home. i suppose it was due to changing the battery, all is well.
thanks all |
