Old 05-27-2008   #11
karterdon
karterdon's Avatar
Default Re: Help! Injector Question
Pat,
I have O-rings that I can sell you - They are made of Viton rubber - excellent fuel resistent, and temp range. If you are interested let me know. e-mail - karterdon@aol.com or 847/736-1144
Don Yoakem
91-#267 Dark Red Met
karterdon is offline   Reply With Quote
Old 05-27-2008   #12
key_on
Originally Posted by GOLDCYLON
Replace the wires and the coil packs. Its a no brainer while you are there cleaning out the gook from the weep hole galley as well. Coil packs (AC Delco) Replacements are about $155 for all four on Ebay and the Delco Replacement wires (628Ds) are about $50.
Definitely going to replace the plugs and wires. I'm going to leave the coil packs alone. The car has operated flawlessly, with the exception of a secondary injector that died. The valley of the engine is remarkably clean. I'm trying to mess with as little as possible. You know what they say about if it ain't broke ...
key_on is offline   Reply With Quote
Old 05-27-2008   #13
key_on
Originally Posted by karterdon
Pat,
Don Yoakem
Thanks for the offer Don. I already have a set on the way. I should have done my homework a little better and had them in hand before I tore everything apart. Next time I'll know.
Old 05-27-2008   #14
Jeffvette
Make sure you use a little dielectic grease on the plug ends on the coils as well as the spark plugs. Seen a few coil packs with corrosion on the coil towers.
Go ahead and tighten down the breather box bolts as well, or at least check them.
Old 05-27-2008   #15
tccrab
tccrab's Avatar
Great advice Jeff. I was going to advise him of the breather box bolts but you beat me to it.
TomC
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 05-27-2008   #16
KO consider it $155 of insurance. On a 91 the coils tend to be a little suspect after 17 years under the heat of a plenum. Pull em and keep em has a handy spare. One thing to rule out after all that work under the plenum. But hey your call.
Old 05-29-2008   #17
key_on
Thanks to everyone's suggestions. Some I had already thought about, others I had not. I just hope the damn thing runs after I put it back together.
Pat
