Old 05-13-2008   #1
Default Byron Dates
Patiently I spent all winter porting my intake, mostly with a Dremel which is akin to digging your way out of prison with a spoon, and now I am waiting for the first Byron test and tune so that I can best my 12.54 from last year.
So whats the ETA on a track day here in Il? Pete I know you saw my handy work on the plenum and are probably running alittle scared at this point, but I promise not to spank you too bad(this is called baiting )
Dominic, Hans, Don, Jeff, PAul, Al, ..........anyone interested in going this month?
Anyhow, fired up and ready to see how it runs.
92 ZR1
#234
LGAFF is online now   Reply With Quote
Old 05-13-2008   #2
Default Re: Byron Dates
Lgaff,
This month means this coming weekend. Next weekend is Memorial Day.
Might want to shoot for the 31st.
Old 05-13-2008   #3
92 ZR1
#234
This month...no, maybe October...I need to at least DRIVE my car a bit first
Old 05-13-2008   #4
Jeff-This month...no, maybe October...I need to at least DRIVE my car a bit first.
Drive it a bit to the track, and then drive it a bit down the 1/4 mile.
91 ZR1
#234
Old 05-13-2008   #5
Looks like a few vettes are going on the 17th.
92 ZR1
#234
Old 05-14-2008   #6
92 ZR1
#234
I'm up for moral support at the moment. Gotta check out a vibration thing before "tracking" it.
I see y'all go Byron to run. Is the Route 66 track too expensive or ???? It is a lot closer than IN (south of Joliet on - IL 53 (old US-66)). The reason I mention it is b/c they have scheduled "Test and Tune" days on a semi-regular basis during the summer months. From what I understand, it is a "come one, come all" format.
I have a good friend that works there and I can get the particulars, if that should interest anyone. (Forgive my ignorance re the "66" track, as I've never looked into running there up to now.)
P.
Old 05-14-2008   #7
P.
some of the faster guys might be lucky to get through tech, I also heard that there are way too many cars that go to test and tune, which is only during the week and if you don't get there early enogh you may not get to run.. I ran my 89 there 10 years ago when the track frist opened.. That same yer I ran it at Byron and "Da Grove" and ran the SAME at all 3 tracks .
Also Byron is in IL out by Rockford, Paul, you are thinking of US 41.. in IN
Old 05-14-2008   #8
US 41....Yes, that is the one I was thinking of. (You can tell I don't drag race much, huh? Auto cross / rallies are more my thing, actually.)
P.
Old 05-14-2008   #9
karterdon
karterdon's Avatar
LGAFF,
I am pretty much shot for this month with having gone to B.G. and now with memorial day weekend coming - I have to go to a wedding in St. Louis that weekend. so kiss the month of May good by. However - I had a Great time at the Drag's in B.G.
Don Yoakem
91- #267
Dark Red Met.
karterdon is offline   Reply With Quote
Old 05-17-2008   #10
Planning on a Byron run tomorrow if the weather is nice....ran the car today, peeked between the runners, secondaries are opening, etc
Only issue is a high idle, no vac leaks, appears throttle cable or throttle bodies are sticking alittle and not letting the blades close all the way. A small tap and it goes back down to 750rpm.
92 ZR1
#234
