Old 05-03-2008   #11
Demps
Demps's Avatar
Default Re: 10 PSI dyno numbers are in...
Simply AWESOME!
Old 05-03-2008   #12
RHanselman
RHanselman's Avatar
Originally Posted by Jeffvette
Looks good Ron. Can we get a graph mapping RPM instead of MPH?
Ask and you shall receive... I added it up top...
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1961 White with Red Int
Old 05-03-2008   #13
gbrtng
gbrtng's Avatar
Fantastic - look at the area under the curves !!!
Old 05-03-2008   #14
Nick
Pretty sweet, Ron. Congrats to you and all involved!
Nick
ZR-1 Net Registry Founding Member #32 - lapsed...
Old 05-05-2008   #15
32valve
so when is the 19+psi dyno sheet showing up?
32valve is offline   Reply With Quote
Old 05-06-2008   #16
You must have missed this comment >>>
"We didn't get a chance to put the high flow pumps in so we stopped while we still had fuel. We'll change the pumps after BG and push her up a few pounds"
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg
http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif
"The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC
" We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln
