Old 10-01-2024   #1
Ozruss90
Ozruss90's Avatar
Default Scan tool
Is there an OBD1 scanner on the market, other than the Tech 1 that widely referred to, that is acceptable for basis diagnostics, code reading and clearing ?
Seems when I type in OBD 1, I keep getting OBD 2 scanners or they claim it will do 2 and 1 which sounds suss to me. Could someone please advise and / or steer me in the right direction. TIA
Cheers, Rusty 🇦🇺
Ozruss90 is offline   Reply With Quote
Old 10-01-2024   #2
AlbanyBrian
AlbanyBrian's Avatar
Default Re: Scan tool
If you want to use a laptop computer you can get DataCat. It is a product of Tunercat. You can get the software, purchase and then download, and the cable to connect your laptop to the diagnostic connection on the car. There is a lot of data that you can get from the car with this software tool, I think all the data that the ECU gets from the engine, it is very useful I think and I am only a novice at using and understanding all the available data.
1993 ZR-1, #135, cool car
2008 Z06, fun car
1985 RIP, was a fun project/track car
AlbanyBrian is offline   Reply With Quote
Old 10-01-2024   #3
Ozruss90
Ozruss90's Avatar
Thanks Brian for your response. I will check that out 👍
Old 10-01-2024   #4
scorp508
Code reading and clearing can be done via paperclip or the cluster itself.
Besides those methods....
Similar to a Tech-1, I use a Vetronix MasterTech w/GM cartridges I picked up on eBay to read/clear codes, spot check other OBD1 information, or perform other simple tests it can do.
One of these, but you need to have the GM cards.
https://www.ebay.com/itm/335578210632
When I want more data over a period of time or to see certain attributes together at once, then I use TunerPro RT with a USB cable from Red Devil River to my OBD port to datalog. 90-93 use the 12-pin OBD1 style port while 94/95 use the 16-pin OBD2 style port even though the vehicle still runs OBD1. They offer an adapter between the two styles.
https://www.ebay.com/itm/363678152938
TunerPro RT: https://tunerpro.net/downloadApp.htm
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite
1994: ZR-1 #150, Admiral Blue / Black
2015: Z06 Coupe, Z07, M7, Arctic White / Red
scorp508 is offline   Reply With Quote
Old 10-01-2024   #5
robertcope
I can't tell you what will work, but I recently purchased a Actron CP9690 and it does _not_ work with my '95. It connects but gives a link failure as soon as data starts to stream.
robertcope is offline   Reply With Quote
Old 10-01-2024   #6
I use an Android phone, OBD1 cable with an OTG adapter on the phone,
Then I use the ALDLDroid App and it just so happens I wrote the Scan Definition files for 90-95 ZR-1s.. the ADX files work with both TunerPro and ALDLDroid
Old 2 Weeks Ago   #7
Young1
Young1's Avatar
I use an old Snap-On MT2500. Requires the card for GM obd1. Available on eBay at reasonable cost.
Steve Young
Second Owner
SOLD
SOLD
