Old 07-01-2024   #1
mlipmd
Default Re: ZR-1 Oil Change
You guys are inventing and trying to solve a problem that doesn't exist.
Fill vs. no fill.
It probably and practically makes very little difference.
If you watch this video (https://www.youtube.com/watch?v=zLBgIve1YzY) by the same guy, increased engine wear with having an unfilled vs. a filled filter in startup only happens with lower viscosity oils and does not happen with higher viscosity oils. And it would only happen for a few seconds anyway on the first startup after an oil change.
Either way, your choice, hopefully the anti-drain valve in whatever filter you choose, if you fill it first, will work, and you won't dump a large amount of oil all over the engine and the flloor.
mlipmd is offline   Reply With Quote
Old 07-02-2024   #2
tf95ZR1
tf95ZR1's Avatar
I agree.
But some have even installed pre-oil systems.
In medicine the question is: "Is it really clinically
significant?" I think not.
That is one benefit of Z ownership. You can do
WHATEVER you want to YOUR car.
Unless you are in California.
T
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
Old 01-23-2025   #3
Originally Posted by tf95ZR1 View Post
I agree.
T
See......California Law On Modifying Engines
