04-01-2024 | #1 |
Front Crank Seal
It appears that the front crank seal is leaking on my 1990 ZR1. I expect this will get expensive if I can even find someone to do it. Not sure I want the neighborhood mechanic doing either.
I am in Huntsville, AL. Any recommendations on where I should take this for repair? |
04-01-2024 | #2 |
Re: Front Crank Seal
Give South Georgia Corvettes a call. Talk to Aaron Scott at 229-224-2919.
He is located in Thomasville,GA. I work with him when he needs extra help. Or check out repair shops on Zr1netregistry. John 1990 White/Black # 2546 one of a few 4l8OE eq ZR-1;s |
04-02-2024 | #3 |
From Huntsville, AL, the closest professional shop for C4 ZR-1/LT5 service is in New Concord, KY. 233 miles ve 482.
Graham Behan, Lotus Engineer. 260-701-8860 Assigned to on-site at Mercury Marine, Stillwater, Oklahoma, to see the LT5 into production.
04-02-2024 | #4 |
Not an easy fix.
Engine will have too be raised significantly or removed completely to remove the crank dampener and old seal. Front seals seldom leak. Recommend double checking to confirm leak source before diving in to replace the front seal. Sent from my iPhone using ZR-1 Net Registry
04-03-2024 | #5 | |
04-03-2024 | #6 |
I had the bolt holding the crank pulley come loose and sprayed oil everywhere. I pulled the bolt, sealed the threads with blue locktite and retorqued the bolt.
LT5 Red/Red |
