05-01-2023 | #1 |
LT5 Engine & Components for Sale
Have many LT5 engine components and several engines for sale. the list is too long for one post. If you are interested in or need another specific part, contact me. if may take time to respond depending on the number of requests received. Pic are available for all items, shipping not included in price, local pickup (Louisville, KY) preferred for larger/heavier items.
90-92 Crankshaft, main & rod journals are standard, pick #1 $750. 90-92 New oil pump assembly (2 bolt), pic#2 & 3: SOLD New oil pump housing available without gears/pressure relief valve, pic #4: /$100 93-95 New oil pump assembly (4 bolt) pic #5: SOLD New oil pump housing available without gears/pressure relief valve:$100 90-95 PN 1006-7512 carbon seal assembly for oil pump: $100 Used 90 LH & RH heads with valves, springs, retainers: $1,500 32 (Complete Set) New Titanium valve retainers: $425 New GM 94 MY 405 HP/4 bolt create engine (Original shipping container), includes clutch assembly, bell housing, a/c compressor, wiring harness: $13,000. Used 90 engine (less throttle body and coil tray), includes DIS ignition module, a/c compressor, wiring harness & flywheel clutch assembly: $5,800. Last edited by billkirchhofer; 05-08-2023 at 08:34 PM. |
05-10-2023 | #2 |
Re: LT5 Engine & Components for Sale
Tensioner by chance?
05-12-2023 | #3 |
Used 90 engine (less throttle body and coil tray), includes DIS ignition module, a/c compressor, wiring harness & flywheel clutch assembly: $5,800. Interested, Pics please |
05-29-2023 | #4 |
Interested
06-12-2023 | #5 |
Hello do you have the ecm?
08-14-2023 | #6 |
Do you happen to have the tensioner pulley by any
