Old 06-19-2023   #1
kieranod1
Default Secondary vacuum pump test
Hi guys, my 91' was running rough so I got so I got Marc's plenum video a new set of seals and gaskets from Jerry and started in. My vacuum pump was running continuously so I figured it was a leak under the plenum and while I was there I'd clean her up and do some preventative maintenance. I started at the vacuum reservoir and worked my way to the pump. I put my finger over the port that goes to the reservoir and nothing, pump keeps running. When I put my finger over the bottom of the "L" shaped port that runs to the top of the pump, she stops. Any ideas? Thanks
kieranod1 is offline   Reply With Quote
Old 07-03-2023   #2
kieranod1
Default Re: Secondary vacuum pump test
Hi guys, just got my pump from Jerry and I realized that the vacuum nipple on the old pump was broken off and I was using the ambient port for vacuum. No wonder it kept running, anyway putting the LT5 back together and we'll see how it turns out.
Old 07-04-2023   #3
HAWAIIZR-1's Avatar
Here is some info about the check valve that was the problem on mine.
https://www.zr1.net/forum/showthread.php?p=221908
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 07-28-2023   #4
That planum pull CD Marc makes it a must for anybody doing this for the first time. The fact that you can energize/operate the system and know if it's working before the plenum goes back on is worth the price alone.
Old 08-04-2023   #5
kieranod1
Hi guys, thanks for the help. I have the new pump installed and it works fine but it still takes a long time to pull enough vacuum to shut off the pump. then the pump comes back on after approximately 2 minutes. I'm sure the connectors on the vacuum lines are old and maybe dried out. Is there any sealant out there that I can use? I can't find the sealant that Mark uses on his video anywhere, I just need to close this issue out before putting the plenum back on. Thanks for your help!
Old 08-04-2023   #6
You need to find the leak before anything else.
