Old 07-20-2023   #1
Starman
Starman's Avatar
Default Infinity Lube
Has anyone used this friction modifier in their oil?
Old 07-20-2023   #2
bob@tradeshowconsulting.c
Default Re: Infinity Lube
never heard of it ... and im an oil fanatic
bob@tradeshowconsulting.c is offline   Reply With Quote
Old 07-21-2023   #3
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
A Buzz Lightyear product?
(sorry)
https://www.fuelox.com/product/fuel-...on-eliminator/
Looks intriguing, but no, have not used it.
Marty
Old 07-22-2023   #4
Starman
Starman's Avatar
Just had a presentation at work on it. Claimed 40hp in engines. Dubious to say the least. Supposedly has been around for 30 years, given the lack of response, doesn?t appear to be a miracle I?ve missed out on.
Old 07-22-2023   #5
TX '90 ZR1
TX '90 ZR1's Avatar
My thought on 99.9% of additives!
Not sure what the other .01% is, but don't want to make an absolute statement!!
Kenny
1990 #442
Old 07-26-2023   #6
Great White
Great White's Avatar
The info in the advertisement sheet says "900 degree flash point." At the bottom in the fine print it says "believed to be accurate at time of issue."
MSDS says 270 degree flash point.
False advertising.
So here's what we can deduce from the info they provide:
- It's a plant based oil.
- There is very little actual data on its chemical properties aside from flash point and kinematic viscosity.
- The only actual wear test info provided has no data on what the actual test results were (like a scar size on a gear tooth or bearing) because "the weld point exceeded maximum limits." That doesn't sound good.
Sent from my BBF100-2 using ZR-1 Net Registry mobile app
Great White is offline   Reply With Quote
